low lift long arms - JeepForum.com
post #1 of 11 Old 06-25-2012, 02:42 PM Thread Starter
XJcaveman
low lift long arms
anyone running long arms with little lift? I have a 6.5" long are setup off a old xj and was gonna transfer it too my new one, but I took it wheeling with just a BB and some junk 30's and I had a blast. So I think I wanna shoot for 33's as low as possible, but still use the long arms.
1999 Jeep Cherokee.
2"BB for now.
XJcaveman is offline
post #2 of 11 Old 06-25-2012, 03:32 PM
Motorcharge
Never seen em for XJs but I know they make them for Wranglers but all the ones I've seen have been ~$3000.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 11 Old 06-25-2012, 03:38 PM
whitexj98
At 4.5 inches my long arms are pretty much parallel to the ground, any lower and they will start to point up.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 11 Old 06-26-2012, 10:58 AM
ibjeepin95
It's all about where your mounts are. Check out ktmracer419. He used to run a little over 2 inches, 37's, and a 3 link.
ibjeepin95 is offline
post #5 of 11 Old 06-26-2012, 12:11 PM
whitexj98
True, I was talking more to the "bolt on long arms" im running tnts.
post #6 of 11 Old 06-26-2012, 01:22 PM
ibjeepin95
I see. The Clayton kits will work with 3 inches that I have seen.
post #7 of 11 Old 06-26-2012, 03:04 PM
dcorn
Depends on the mount location and the arm design.
The TnT kit has chassis side mounts up very high, probably the highest of any kit out there. Problem is the arms are bent up and in for clearance, so if you run the kit with too small of a lift, you might have some interference. If the arms were mounted that high, but straight, you'd be better off with a lower lift.
Length has a lot to do with it as well. My 3-link kit pushed my front axle an inch or two forward, and that's with about 5" of lift. If I lowered the front end down, it would go even further forward.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #8 of 11 Old 06-26-2012, 08:03 PM
ibjeepin95
Not to get off topic, but how do you like the Poly Performace 3 link?
post #9 of 11 Old 06-27-2012, 10:02 AM
Clayton
I have Re long arms. The shortest spring i have ran is a 3" spring with 35's. If your gonna run a true long arm in front with little lift its gonna take alot of work to set it up right. Right now i have some 4" springs in front & absolutely love how it works. Even with 4"springs alot of sheet metal was sacrificed to get some good up-travel.
Clayton is offline
post #10 of 11 Old 06-28-2012, 05:39 AM
dcorn
It's awesome. No idea why more people don't run it. Maybe because you have to weld a UCA mount on the axle? I had it installed in a day with a few friends helping.
Competitive price with most other high-end long-arm kits, but it's not a radius arm, so it doesn't have any of those drawbacks. Built for race teams basically, so it's beefy as hell. Flexes for days but street manners are still great. One of the best mods I did to the Jeep.
dcorn is offline
post #11 of 11 Old 06-28-2012, 07:50 AM
ibjeepin95
If I go three link it will be between Clayton and Poly Performance.
4.5" lift - benefit of long arms? specialEDGE XJ Cherokee Technical Forum 20 12-11-2011 08:07 PM
How long control arms with 6,5" lift? pigg MJ Comanche Technical Forum 3 08-17-2010 01:46 PM
Converting adjustable short arms to long arms djlarroc XJ Cherokee Technical Forum 6 11-15-2009 10:15 PM
How little lift with long arms ? bobfortier XJ Cherokee Technical Forum 4 10-14-2008 06:03 PM
4 1/2 Inch Lift Short or Long arms CanadianCook XJ Cherokee Technical Forum 1 06-22-2005 12:18 AM
