Lost engine ground strap nut - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Lost engine ground strap nut
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCCOR is your 1 stop source for everything Jeep!Stainless Steel Door Hinge Pins
Unread 01-11-2015, 04:52 PM   #1
GolfJeep13
I have a 1998 XJ 4.0L I was replacing the ground strap for my engine and lost the nut that screws the end of the strap on to the engine. If it help its the strap that attaches to the back on the engine and to the fire wall. If anyone knows what size that nut is that screws down on to that strap at the rear of the engine it would be amazing.
GolfJeep13 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 08:44 PM   #2
PaYankee
Attach the ground strap to the last bolt on the fuel rail. Forget the nut.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 10:07 PM   #3
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yup.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
