Looking for small dirt plow... - JeepForum.com
post #1 of 4 Old 05-07-2013, 02:39 PM Thread Starter
BenQQ
1998 FSJ Cherokee
...i can hook to the tow bar on the back of my 98 Cherokee. i'm interested in plowing or scraping up dirt to clear grass to make walk paths or maybe even turning up soil but not to deeply. (I'd go back over with a tiller.) I'm low with small tires. What i'm thinking of is maybe a 12-18" slanted blade that presses shallow into the dirt via gravity...anybody ever heard of such an animal? thanks!
BenQQ is offline
post #2 of 4 Old 05-08-2013, 05:12 PM
cbenez1
Actually I have seen this kind of thing done, only with another kind of vehicle. I believe they call them TRACTORS. You may have heard of them. All kidding aside, if your XJ came with the Massey-Ferguson option you should have no problem tilling the corn fields with it. Ok now I'm done joking. You have low range and your Cherokee could pull a house down if you rig it properly and get enough traction. So why not ? Just be careful not to overload it weight wise as in down force or tongue weight. Just because they will pull a shiotload doesn't mean the springs will support it.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #3 of 4 Old 05-08-2013, 09:49 PM
Muddy97Cherokee
1997 XJ Cherokee
That was great!
But ya, if you have a tiller why not use that? And a shovel or hoe? You could try to build an attachment but gravity wouldn't be the greatest way to dig up the ground. For one it would be uneven as ****! Also when you start at a point and start digging with said attachment it would just dig deeper and deeper the further you go. There is a reason why there are hydraulics on tractors for plowing. It wasn't so you could raise it up and down, well its partially for that, but its for keeping the plow at the same height while plowing. Same reason why planes have hydraulic ailerons that do the same for flying.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #4 of 4 Old 05-09-2013, 06:34 PM
SuperSam
find one from a garden tractor, Or use a chunk of steel, rr tie etc.
Probably not going to find much unless you fab it yourself
SuperSam is offline
