Looking to buy an XJ: Help! - Page 3 - JeepForum.com
post #31 of 63 Old 06-22-2013, 07:38 AM Thread Starter
krawler510
How much tougher is an 8.25 than the D35?
I haven't looked but I imagine replacements of both aren't too hard to find?
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #32 of 63 Old 06-22-2013, 08:16 AM
XJNKY
I've seen a strength test posted somewhere on this forum that suggested that the 29 spline was on par with a D44. I've also heard that they're good up to 35's. Some people like to talk bad about them but I suspect that has more to do with a "must-mod" mentality than their actual robustness. There were certain years of them that Chrysler screwed up something with the shaft/bearing and they develop the "8.25 clunk".
I have a 29 spline, welded, with 3.07's in my trail rig (I know, working on changing that ratio), and I've 5-grand clutch dumped it soooo many times with 31" tractor tires. Wouldn't dare do that with a D35. I know they're only 31's, but they hook HARD.
27 splines are marginally weaker. Have a friend with a 27 spline with a lockrite and 33's, and he has beat on it hard. 280K miles on it and it's still going strong.
If you get one with a D35, it's well worth the $100 to get an 8.25".
XJNKY is offline
post #33 of 63 Old 06-22-2013, 10:18 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Do a D44, cuz you'll wish you had! Period.!.!.
D3<!L!>3D
S8NNG8 is offline
post #34 of 63 Old 06-24-2013, 05:30 AM
DNFJ
Like was said, an 8.25 is comparable to a D44.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #35 of 63 Old 06-24-2013, 08:04 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Imo, if you're gonna do it, do it right the first time. The word comparable has always indicated "slightly less than equal". Thus, the terms "equal to" or "better than" are never used to describe an 8.25.
D3<!L!>3D
S8NNG8 is offline
post #36 of 63 Old 06-24-2013, 08:55 AM
DNFJ
If you're not going above 35s, a built 8.25 is perfect.
Even with a D44, you shouldn't get going above 37s.
But then again it's not a real jeep if it's not on D60s F/R on 44s
Previous:
DNFJ is offline
post #37 of 63 Old 06-24-2013, 09:17 AM Thread Starter
krawler510
35s is the plan. The JK 44s and lockers on my old jeep held up with 35s but I'll push this harder.
post #38 of 63 Old 06-24-2013, 09:26 AM Thread Starter
krawler510
Do I just need different size u bolts to switch axles? Odds of the driveshaft having a comparable connection?
post #39 of 63 Old 06-28-2013, 03:19 AM Thread Starter
krawler510
Bought one:
Stock '99 auto in good shape.
I need this to hang with a fewJK's on 35s. RE4.5 with 33" Mud Grapplers sound good? I really want 35s again but I don't know?
It will be regeared but not before my first wheeling trip or 3.
post #40 of 63 Old 06-28-2013, 07:16 AM
DNFJ
Bought one:
HP30/8.25 on 35s re-geared to 4.56 imo
Previous:
DNFJ is offline
post #41 of 63 Old 06-28-2013, 07:25 AM Thread Starter
krawler510
Sounds good to me. Might even be able to go 4.88 since this will be far from a daily driver.
Just has to make it from Baltimore to Rausch Creek every month or so. And maybe 1 mile to the local boat ramp.
post #42 of 63 Old 06-28-2013, 07:30 AM
Muddy97Cherokee
1997 XJ Cherokee
This.
4.5 will do with some trimming for 33's. If you plan at staying at 33's 4.10's are the way to go. 35's should be run with 4.56's. 6.5" can clear 35's with some trimming. You will be able to keep up with jk's with 33's. I keep up with them on my 31's.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #43 of 63 Old 06-28-2013, 07:49 AM
XJNKY
^This
XJNKY is offline
post #44 of 63 Old 06-28-2013, 01:40 PM Thread Starter
krawler510
Excellent.
We play in a lot of rocks so I was looking at the JCR GTS, crossmember skid and engine skid. Differential covers. Sound sufficient?
I only banged my rockers good once on the jk with its long wheel base so I'm not worried about those just yet.
Will I need to mess with a pitman arm and track bar raise/drop with the 4.5" lift? The jk was fine with an adjustable track bar and control arms.
post #45 of 63 Old 06-28-2013, 01:48 PM
XJNKY
I believe 4.5" is right there in that area where it isn't absolutely necessary, but it's certainly not a bad idea either. Helps with bump steer.
Also, I think there was something different with the t-case output on 99+ that made vibes worse when lifted? Anyone comment on that? You'll probably need a SYE or cheater (hack-n-tap?). Either that, or a tool box well stocked with spare universal joints.
XJNKY is offline
