post #1 of Old 06-28-2015, 12:20 PM Thread Starter
xjbeast59
looking to beef up my xj and need help
New to the jeep forum and dont know if this is in right spot for discussions? I'm looking into get a lift kit.. read up on a lot of reviews and cannot pick one for the life of me! I want a 4.5 in for my 98 xj and am looking at zone, rustys, or rough country if someone could help me out and give me there review and expierence with them would be greatly apreciated! Thanks!!
xjbeast59 is offline
post #2 of Old 06-28-2015, 12:22 PM
jason m
Nothing but the facts
jason m's Avatar
Moved to XJ forum.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
http://www.jeepforum.com/forum/f149/...buggy-3693817/
jason m is offline
post #3 of Old 06-28-2015, 12:36 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've had no issues with my Rusty's lift in 3+ years. Good equipment for a good price. Others will tell you something good and something bad about every brand. You'll kind of have to make your own decision in the end, usually based on price.
D3<!L!>3D
S8NNG8 is online now
post #4 of Old 06-28-2015, 12:41 PM Thread Starter
xjbeast59
What size lift do you have from them?
post #5 of Old 06-28-2015, 01:35 PM
nolanbalzarini
nolanbalzarini's Avatar
what size tires do you wanna run?
because u can do 35's on 3 inches.
you can even do 40's on 0 inches over stock if your crazy. (hard)
nolanbalzarini is offline
post #6 of Old 06-28-2015, 02:24 PM Thread Starter
xjbeast59
I would like to do 33's cause I know how 4.10 gearing feels with them and I like it
post #7 of Old 06-28-2015, 02:42 PM
nolanbalzarini
3.5 is a lot cheaper than 4+
any aftermarket flare will let you do 33,3.5 fairly easily. with bumpstops
or just hack the crap out of it and run nothing.
post #8 of Old 06-28-2015, 02:56 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I have the full spring replacement:3" front/3.5" rear running 31's with both upper and lower arms replaced too.
D3<!L!>3D
post #9 of Old 06-28-2015, 08:51 PM
FairlanePhil
My 00 had a bastard pack lift and for someone living in the rust belt you may want to consider it.
I grabbed the main leaf from and S10 and lapped it in my stock spring pack. I needed new centering pins to pass thru the stack and I had some U bolts bent up locally for about $25
In the front I got a set of 3" lift coils.
Fors shocks I used JK takeoffs but I hear you can use 96 Ford explorer.
I kept the stock track bar and steering.
My Jeep did get some driveline vibes after the lift so after installing new U joints and that not fixing it, I dropped the transfercase 1".
In the end a $175 slip yoke eliminator fixed the issue.
I extended my front brake lines by rebending the hardlines straight and I never really got the rears taken care of before selling.
I never did get sway bar disconnects. I welded some extra end links on to the originals to make them longer while I saved up the cash
Why do I suggest a bastard pack in back? Because the leaf spring bolts will be a monster to get out if you live in a state where they salt the roads
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
You may not post new threads
You may not post replies
