Looking for advice on what to do to toughen up My XJ - JeepForum.com
post #1 of 5 Old 03-09-2013, 09:45 PM Thread Starter
BGDG280
1991 XJ Cherokee
I have a 91 with a 4.5" lift, 34 x 10.5 Swampers. 8.5 rear. 5spd 3:73 to 1 gears now.
Here is what I have planned; weld the rear diff, possibly swap in a 96 rear diff IF it has the 29 spline axles, swapping in the 96 front diff to get the bigger joints and eliminate the goofy split axle dana 30 lol.
I'm going to have about $1500.00 to spend on this Jeep, I am going to cage it, so there is some expense in pipe.
So with the remaining $1200-1300.00, what do you all think is a good way to go to make this rig as tough as possible so I can be more aggressive off roading?
Mostly trails, but I'd like to do some medium level rock crawling as well.
91 XJ, Yellow, Dirty ALOT, 34 x 10.50 x 15 Super Swampers. Looking for Trails and Off Road fun!
95 XJ 2 Door 5 spd, 2" lift, 31 x 11.50 x 15 Super Swampers....this thing is a bada** for being nearly stock!
BGDG280 is offline
post #2 of 5 Old 03-10-2013, 11:44 PM
Hussler
1992 XJ Cherokee
ford 8.8 rear +hi pinion d30, fab up some bumpers , Winch, frame stiffeners, rocker guards, then a cage made out of TUBING; in that order
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #3 of 5 Old 03-12-2013, 03:56 AM Thread Starter
BGDG280
1991 XJ Cherokee
Thank you Hussler for your advice.
I should have been more clear.
I have warn bumpers front and rear, I bought a 12,000lb winch for it, I was going cut the rest of the rusted rockers out and build skid bars and tie them and the roll cage into the "frame".
On the 8.8, is there really that significant of a difference between it and the 8.25 as far as strength goes? I dont see too many articles on people busting the 8.25s.
I'm installing the D30 out of a 96 Cherokee.
I'll be using electro-welded handrail tubing/piping for the cage, I've used it for years building cages that werent destined for certifications, it works great.
BGDG280 is offline
post #4 of 5 Old 03-12-2013, 04:42 AM
Motorcharge
8.8 is almost twice as strong as the 8.25 and you get disc brakes.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 5 Old 03-12-2013, 08:11 PM
Hussler
1992 XJ Cherokee
I have my skid bars made, recently bought the bender for the cage. Plate your frame, i think I used AJs stiffeners
I think the 8.25 is a fine axle that can stand up to 35"s well, but if your going through the trouble might as well go for the golden child of the narrow wheel base group. 8.8 is stronger in every way and has better after market support
I'm spending the extra $ for the chromoly, only have to build this cage once, might as well go for the best
Hussler is offline
