looking for 3in of lift - Page 2 - JeepForum.com
post #16 of 19 Old 12-19-2013, 05:46 PM Thread Starter
mikbob1313
Originally Posted by Tom95YJ View Post
If you can weld I highly advise adding some 3/16 plate to the underside of the control arms. To beef them up and get oem replacement brake lines for a Yj to extend your lines.
alright, welding is definitely a possibility, i'll look into th lines. ive got a d35 rear axle, the 3 inch lift and 30's wont be to much stress will it?
"The beauty of the second amendment is that it will not be needed until they try to take it." -Thomas Jefferson
mikbob1313 is offline
post #17 of 19 Old 12-19-2013, 06:27 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
31" tires are about the limit for a d35. IMO if you have junkyards near ya. Pick up a 8.25 from a 96-01 Xj. It'll bolt right in and have 29 spline axle shafts I beat on mine with 33's all the time. But the 8.25 will handle 35's in stock trim with out blinking.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #18 of 19 Old 12-20-2013, 11:19 AM Thread Starter
mikbob1313
aight, i'll do some looking lookin, maybe a little more $$$ but do it right do it light
post #19 of 19 Old 12-20-2013, 11:42 AM
sAe23
1995 XJ Cherokee
Originally Posted by mikbob1313 View Post
if i just go 3inches, would i need new control arms or brake hoses like those that come with the more $$ kits?
At 3", the stock length LCA will be about .25" short.
This will have some minor impact on caster and pinion angles, but nothing drastic. Tires larger than stock will appear off-center within the wheel-well.
Brake lines need only have the anchor bracket relocated, but just be sure that they are not the limiting factor when flexing off-road!
sAe23 is offline
