Looking at 1998 Cherokee Sport. - JeepForum.com
post #1 of 10 Old 04-07-2011, 08:51 PM Thread Starter
buggs67
Not sure if this is technical or non-technical. I'm new to Jeep. Will be MY first. What things should I look for on a Cherokee. I'm somewhat mechanically inclined. But by no means an expert. Has 126,000 miles and clean inside and out. Clean history and title.But this is on a dealer lot and since my first Jeep would really appreciate some info on key points to look for.
Thanks
buggs67 is offline
post #2 of 10 Old 04-07-2011, 10:14 PM
Trons
The year is solid. Rust is a big thing, depending on where you're at. Price will be your next concern since it's at a dealers. The '98 came with 2 different rear ends, a Chryco 8.25 and a Dana 35...the 8.25 is preferable, especially if you plan on building it. Other then that, if it's an auto, the AW4 is pretty much bullet proof and if it has the 4.0, that is low milage if it's been cared for.
'03 TJ Rubicon
'16 KL Latitude
'91 Cherokee Laredo, Stock - Sold
'98 XJ - burned :(
Trons is offline
post #3 of 10 Old 04-07-2011, 10:50 PM Thread Starter
buggs67
Thanks Trons,
How can I tell the difference on the axles Chryco or Dana? History report shows Cherokee came out of Michigan but was not there no more than 3 months. It didnt see a winter there. The rest of time was in Texas. I 'll check for rust.
buggs67 is offline
post #4 of 10 Old 04-07-2011, 11:20 PM
MCObray
Here is a chart of the Axle's. In real life, the Chryco 8.25 has a little lip on the bottom, as the Dana 35 doesn't.
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
post #5 of 10 Old 04-08-2011, 06:33 AM Thread Starter
buggs67
MCObray,
Thanks for the info.
buggs67 is offline
post #6 of 10 Old 04-08-2011, 12:20 PM Thread Starter
buggs67
Well looked at the 98 Cherokee today. Asked dealer what has he done to it since he got it. His reply, just detail and nothing else. Even the detail was aweful. Been siiting over a month on his lot. There were oil leakes I could see. Dana rear axle. Rust on surface only that I could tell. Interior was ok with no tear or cuts. Even head liner was in good shape. Started ok, 4x4 seem to work. Let it warm up, no over heating. A/C worked, but heres my question.
There was a very faint low knocking noise while I was in the cab just sitting there letting it idle. Anyone have an idea what this could be? Also when I engaged 4x4, light shows up part time 4wd. Could someone explain what 4wd part time means?
buggs67 is offline
post #7 of 10 Old 04-09-2011, 07:14 AM
Trons
There are two transfer cases that came in the XJ's. a 231 and a 242. A 231 will have a selector indicator that goes from 2wd-4h-n-4l while a 242 will go 2wd-4hpart-4hfull-n-4l.
Part time 4 wheel drive is something you only want to use part time. It locks the front and rear drive shafts together so they both spin at the same speed which means it should only be used on slippery surfaces such as off road so the tires can give to prevent binding.
4 wheel full time is something you can use regardless of the road conditions. The transfer case acts like an open differential front to rear and allows slippage, so you can use it on dry surfaces because the transfer case will slip to prevent binding.
'03 TJ Rubicon
'16 KL Latitude
'98 XJ - burned :(
Trons is offline
post #8 of 10 Old 04-09-2011, 08:41 AM
Millermagic
The knock you hear could very well be the flex plate bolts coming lose, very common on XJs.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #9 of 10 Old 04-09-2011, 01:09 PM Thread Starter
buggs67
Thanks everyone for the info. Will let you know the outcome.
buggs67 is offline
post #10 of 10 Old 04-09-2011, 09:09 PM
96-XJ
1972 CJ5
slight knoocking could be the lifters too. very common no big deal
96-XJ is offline
1998 Cherokee Sport cwreck XJ/MJ Cherokee Non-Technical Forum 9 09-15-2010 09:15 PM
1998 Cherokee Sport cwreck XJ Cherokee Technical Forum 11 09-15-2010 03:02 PM
1998 Cherokee Sport. Please Help ME! bermudaJEEP MJ Comanche Technical Forum 16 11-19-2008 06:46 PM
1998 cherokee sport. What should I buy? xj_sport XJ Cherokee Technical Forum 5 07-10-2008 03:46 PM
New 1998 Cherokee Sport Glazzed XJ Cherokee Technical Forum 7 05-19-2006 09:44 AM
