-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   Long Distance (3000+ miles) Roadtrip- Advice? (http://www.jeepforum.com/forum/f177/long-distance-3000-miles-roadtrip-advice-1572233/)
untaker 09-06-2013 02:30 PM
I'm heading across the country (east to west) at the end of this month. My girlfriend and I are moving to Washington. I'll be driving my 2000 XJ, and I'd like to hear what you guys have to say on taking the Jeep that far! So far, what I've done/plan to do is:
- New tires
- New fuel pump and sensor (needs replacing anyway)
- New oil sending unit (also needs replaced)
- Oil change
- New air filter
- spare serpentine belt
- tool kit
I'm also not sure if I should have my suspension looked at. I'm going to be loaded with significant weight since we're not using a moving truck. All our stuff will be split between her Mazda and the Cherokee, with the XJ carrying the majority.
Any and all advice is welcome!
Tom95YJ 09-06-2013 07:46 PM
2 Attachment(s)
- New tires
- Oil change
- New air filter
- tool kit
I would install new spark plugs and flush the cooling system. Replace the diff fluid with a good synthetic fluid. Carry spare fluids and belts. And you should be good
untaker 09-07-2013 10:38 AM
If I already have a little bit of sag in the back, would it be beneficial to have that checked out before loading it down with all my worldly possessions? Or would it be fine since I'm going to be on roads (mostly flat) the entire time?
Tom95YJ 09-07-2013 01:40 PM
2 Attachment(s)
If your sagging in the rear your springs are shot. Just throw on a 1" shackle before the trip if your concerned once you get to the destination buy new springs
untaker 09-09-2013 07:27 AM
How much you think I would be looking at if I had a mechanic do that, parts and labor? I don't have many tools or space at my disposal (apartment complex).
Tom95YJ 09-09-2013 11:27 PM
2 Attachment(s)
Shackles 100.00 or so Labor prob 1-2hrs
untaker 09-11-2013 06:53 AM
I might do that then, there's going to be quite a bit of weight in the back. Thanks for the help!
The time now is 07:19 AM.
