lk 93xj build - Page 27 - JeepForum.com
post #391 of 416 Old 03-18-2014, 11:58 PM
justanotherjpr
There's a facebook group, spokane area 4x4 that might be helpful to you. Interested in the IRO kit myself but unsure about the single shear hiems and if they are legal in WA. Strange that template didn't fit for you. I want a set of those Napier flares too.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #392 of 416 Old 03-19-2014, 12:10 AM Thread Starter
lk123
1993 XJ Cherokee
Well I asked for the cut off ones that jake used but still doesn't match my brothers 98 since they are supposed to be for the 97+
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #393 of 416 Old 03-24-2014, 01:38 PM Thread Starter
lk123
1993 XJ Cherokee
The iro steering kit just came in to my work
lk123 is offline
post #394 of 416 Old 04-24-2014, 01:51 AM Thread Starter
lk123
1993 XJ Cherokee
still havent put on the iro kit yet :/
lk123 is offline
post #395 of 416 Old 05-25-2014, 10:33 PM Thread Starter
lk123
1993 XJ Cherokee
got my iro kit on and havent done the duel sab kit yet. my steering is still sloppy and everything is installed correctly. idk maybe somethings wrong in my steering wheel. anyways the the kit is sorta a pain in the *** so my dad helped me out and even then since the way the joints are the drag link still is not how i would like it it sorta sits and wobbles due to the fact the joint ends are just spheres and not like a normal tie rod end
lk123 is offline
post #396 of 416 Old 05-29-2014, 02:07 AM
justanotherjpr
I think your frame side track bar mount is too low compared to your drag link off the pitman arm - maybe it's the angle of the picture? Can you get a better picture of the passenger side knuckle attachment? If you have a helper turn the wheel back and forth, where is the play?
post #397 of 416 Old 06-06-2014, 06:23 PM Thread Starter
lk123
1993 XJ Cherokee
Oh Yay my turn signal switch broke lol
lk123 is offline
post #398 of 416 Old 07-09-2014, 08:55 AM Thread Starter
lk123
1993 XJ Cherokee
I haven't touched the jeep in a while I need to do a oil change and Trans fluid change. Also I went to the junk yard and destroyed a steering column to get some parts and also picked up a new wiper arm. Now I just need to figure out how to not destroy my steering column while fixing it lol. Also got a bit of money and will order Napier flares soon.
lk123 is offline
post #399 of 416 Old 07-12-2014, 12:45 PM
Camfam07
in this pic... if I am not mistaken someone with more knowledge of this will chime in, but i thought on this kind of steering the TIE ROD/SPHERE on that pass side knuckle should it not run on top of the knuckle? just seems it should be on top and not hang down all the way like that. just my opinion.
Camfam07 is offline
post #400 of 416 Old 07-12-2014, 12:54 PM Thread Starter
lk123
1993 XJ Cherokee
Setup just like the instructions that came with it. If you google it everyone els is the same, Its just the angle of the picture i guess that makes it look wonky
lk123 is offline
post #401 of 416 Old 07-12-2014, 12:58 PM
Camfam07
ok cool, just checking just seems it should have been flipped but I think those are the other kits that require reeming and drilling and all that fun stuff. not sure, have you taken it to a local 4WD shop and have them adjust everything?
Camfam07 is offline
post #402 of 416 Old 07-12-2014, 01:04 PM Thread Starter
lk123
1993 XJ Cherokee
No that costs money. Plus my dad is a mechanic/body guy he helps me out alot. I didn't want to get into rimming out stuff and changing anything so I went with bolt in.
lk123 is offline
post #403 of 416 Old 07-18-2014, 08:18 PM Thread Starter
lk123
1993 XJ Cherokee
Napier flares arrived today
lk123 is offline
post #404 of 416 Old 08-29-2014, 12:07 PM Thread Starter
lk123
1993 XJ Cherokee
Changed the thermostat, what a pain in the *** that bottom bolt is. Also my vacuum line to my vacuum canister broke so I need to get a new one of those. And my electric fan is not coming on at 190/210 or whatever jeep hit 220 and still nothing so more to fix.
lk123 is offline
post #405 of 416 Old 09-01-2014, 09:38 AM
Amesbear
I bought a vacuum line at my local dealer for under $17. Check the link in my signature for pics of where it starts, ends, and routing.
My XJ thread: http://www.jeepforum.com/forum/f177/im-back-xj-2628914
Amesbear is offline
'93Xj with crappy internal hydraulic bearing. shstrach XJ Cherokee Technical Forum 0 01-21-2010 02:25 PM
Need to reattach fender flare 93XJ WoodyinTroy XJ Cherokee Technical Forum 2 07-24-2009 11:05 AM
key wont turn in ignition, 93xj. problems bughunter XJ Cherokee Technical Forum 1 04-13-2009 10:34 AM
newbie with 93xj mainiac XJ Cherokee Technical Forum 3 03-22-2007 05:28 AM
93xj missbatl@bellso XJ Cherokee Technical Forum 7 03-16-2006 02:59 PM
