lk 93xj build - Page 25 - JeepForum.com
post #361 of 416 Old 04-16-2013, 08:36 AM Thread Starter
lk123
1993 XJ Cherokee
Thanks its been one of the best things i have done to the jeep
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #362 of 416 Old 04-24-2013, 08:44 PM Thread Starter
lk123
1993 XJ Cherokee
Had the day off so i went out to pull & save picked up some tow hooks off a old xj and a zj tierod upgrade for 14 bucks. found a 8.25 also but needed help so i had to leave it
lk123 is offline
post #363 of 416 Old 04-28-2013, 03:38 PM Thread Starter
lk123
1993 XJ Cherokee
Picked up the 8.25..... But I busted off a shock mount bolt also took the gears and stuff from the front axle and then grabbed the front door seals off a 98 they are better condition and also thicker than mine.
lk123 is offline
post #364 of 416 Old 04-29-2013, 08:18 PM
Project1
you can prob just drill it out and put a bolt and a nut though it. The TJ's use a bolt and nut.
Project1 is offline
post #365 of 416 Old 04-29-2013, 08:30 PM Thread Starter
lk123
1993 XJ Cherokee
My work sells a dorman universal stud but my dad says he wants to mess with it first.
lk123 is offline
post #366 of 416 Old 05-06-2013, 11:25 PM
justanotherjpr
Drill it out and put a bolt through it. I'll weld the bolt to the bracket for you. Before you do much work make sure it is a 29 spline 8.25
justanotherjpr is offline
post #367 of 416 Old 05-07-2013, 10:48 AM
VegasGT
1988 MJ Comanche
I broke the threaded portion off the shock mount stud on my 8.25. Thought about drilling it out but if you look at it youll see thats a LOT to drill through.
I ended up grinding the remaining threads down flat to the shank and welding a grade 8 bolt of similar thread size to it. Held up great for a few months now. Something to consider because I had it fixed way faster this way.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #368 of 416 Old 05-07-2013, 11:48 AM Thread Starter
lk123
1993 XJ Cherokee
Came off a 98 with 355 gears. It's got a big round part on the other side of the bracket did u take that off to?
lk123 is offline
post #369 of 416 Old 05-11-2013, 03:52 PM Thread Starter
lk123
1993 XJ Cherokee
here's some pics
lk123 is offline
post #370 of 416 Old 05-18-2013, 02:35 PM Thread Starter
lk123
1993 XJ Cherokee
Some punks broke into my jeep found doors open in the morning
lk123 is offline
post #371 of 416 Old 05-25-2013, 11:58 PM Thread Starter
lk123
1993 XJ Cherokee
Pick up a new tie rod end and adjusting sleeve for the v8 tie rod and installed it today, now i dont have as much play in my steering as i did before but still need to do an alignment
lk123 is offline
post #372 of 416 Old 06-23-2013, 02:13 AM Thread Starter
lk123
1993 XJ Cherokee
Have one of the two 98 door seals installed very nice and better seal but have yet to get the time for the other oen
lk123 is offline
post #373 of 416 Old 09-04-2013, 09:08 PM Thread Starter
lk123
1993 XJ Cherokee
Installed the 8.25. Still working on brakes and having driveshaft issues
lk123 is offline
post #374 of 416 Old 10-10-2013, 03:04 PM Thread Starter
lk123
1993 XJ Cherokee
Put in all new steering. But noticed drop pitman arm is wearing out and with the new stiff tre's and stuff I now have a popping sound, also still have a little slack in the steering wheel
lk123 is offline
post #375 of 416 Old 11-02-2013, 01:13 PM Thread Starter
lk123
1993 XJ Cherokee
Regeared to 456 yesterday. Getting tires today. Goodbye savings
lk123 is offline
'93Xj with crappy internal hydraulic bearing. shstrach XJ Cherokee Technical Forum 0 01-21-2010 02:25 PM
Need to reattach fender flare 93XJ WoodyinTroy XJ Cherokee Technical Forum 2 07-24-2009 11:05 AM
key wont turn in ignition, 93xj. problems bughunter XJ Cherokee Technical Forum 1 04-13-2009 10:34 AM
newbie with 93xj mainiac XJ Cherokee Technical Forum 3 03-22-2007 05:28 AM
93xj missbatl@bellso XJ Cherokee Technical Forum 7 03-16-2006 02:59 PM
