Lighter M101A2 - JeepForum.com
post #1 of 8 Old 04-16-2011, 09:14 AM Thread Starter
96XJ0507
Lighter M101A2
So in a followup to my earlier thread asking if it was possible to lighten up an M101a2 or if it was feasible without it. So, I found that there is about 100lbs of bracing on the bottom of the trailer box that can go if you weld the box to the frame instead of bolt it.
So I did that and decided I wanted to make it a little smaller, so here is what a couple hours of grinding, hammering, and cutting can produce. When I get the sides cut to match and welded up I'll put those up as well. Also found that by flipping the tongue tubes 180 that I'll be able to cut them back 12" and still have them pretty close together and then I'll box the front end in with the lunette sandwiched in there. It takes some time, but it is a lot cheaper than an M416 in this area. Also, I'll get a final weight before the axle swap and after when I get around to it.
It is now a 5.5' long bed by 4'2" and the tongue will be about 40" long from box to center of lunette.
96XJ0507 is offline
post #2 of 8 Old 04-29-2011, 10:47 PM Thread Starter
96XJ0507
New axle is on along with modifications to the tongue and additions to the frame. Total weight of frame and axle and tongue (no box) is 340lbs. Will update once wheels and body are installed.
96XJ0507 is offline
post #3 of 8 Old 06-22-2011, 11:47 AM
Litergy
It's been awhile. Are there any updates?
Litergy is offline
post #4 of 8 Old 06-22-2011, 11:52 AM
Litergy
I would also like to see what you did with the tounge? I'm in the process of modifing my m101A2 also. What axle did you go with? Do you have the part number?
Litergy is offline
post #5 of 8 Old 06-22-2011, 05:50 PM Thread Starter
96XJ0507
For the tongue I flipped the tubes to the inside of the mounts to draw them in for a shorter tongue. Then I boxed in the tongue and welded the stock lunette into position. For the axle I used southwest wheel http://www.southwestwheel.com/store/...ler-axles.aspx . I need to finish welding it the rest of the way. The only thing I had with this axle company is I had to weld on my own perches. Just make sure you get them the way you want them before welding. I still need to get updated pictures, I only have one of it tacked together.
As for the lunette though, I'm changing mine to a rotating setup to give more articulation. I bought a new lunette and will make a tube to hold some bushings to mount the Lunette in. The the lunette can rotate about the long axis if the trailer and jeep are ever on alternate planes (like crossing a wash on a diagonal).
96XJ0507 is offline
post #6 of 8 Old 06-25-2011, 04:24 PM
Litergy
Looking good!
Litergy is offline
post #7 of 8 Old 06-25-2011, 05:33 PM
GregB_00XJ
Wow, that looks great. A lot of work, but it will be worth it. I had the opportunity to buy one of those as well...WAY too big for me, but it was 1/3 of the cost of the M101 CDN2 I bought.
This is a nice build.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #8 of 8 Old 07-16-2011, 05:59 AM
DorkAlert
I just won an m101a2 and have been thinking about how to cut it down to a more manageable size to be towed behind my TJ. I do, however, want to keep the military axle and brake system. Your thread is giving me a lot of ideas. Please post more details. I really like what I am seeing.
Forum posts, text messages, and emails do not carry tone. Nothing better than a good face to face or a phone call.
DorkAlert is offline
CB Power from Cig Lighter? CalebsXJ XJ Cherokee Technical Forum 9 11-07-2008 07:37 PM
fuse for cig lighter...where? jeepbro's XJ Cherokee Technical Forum 2 05-11-2008 10:07 PM
Cig lighter fix? Seabastion XJ Cherokee Technical Forum 2 12-01-2007 06:47 PM
Cigarette Lighter icraker XJ Cherokee Technical Forum 1 08-18-2006 08:48 PM
cigerette lighter 96xjscottc XJ Cherokee Technical Forum 1 07-22-2006 06:17 AM
