lift problems... help!!! - JeepForum.com
post #1 of 6 Old 07-30-2011, 10:04 AM Thread Starter
nessbran
1986 XJ Cherokee
well im not sure if i am just retarded or what but my buddy and i took off the front axle to clean and replace bushings, and add a 3inch lift now we got all 4 arms atached and cant get the springs back under. it looks like were not geting a lot of travel?? does anyone have any ideas where we went wrong or wtf is going on here because i sure dont http://www.jeepforum.com/ubb/brickwall.gifnt and its driving both of us crazy
please help!!! here are some pics hope someone can see the problem here. the lca are hitting the shock mounts not allowing the axle to drop down any more
nessbran is offline
post #2 of 6 Old 07-30-2011, 10:09 AM
Tewing04
1992 XJ Cherokee
3 inch springs should fit fine with stock length control arms, but either way when adding a lift you need to remove the lower control arms from the axle side to get the coils in. Then use a floor jack to align the control arms to get the bolts back in there. If you can get your hands on a coil compressor that would make it a lot easier too.
If you still can't get them in remove the axle side of the track bar too. Coils should be the first thing to go in and then add the control arms and track bar after that.
Check out the build thread!
http://www.jeepforum.com/forum/f22/1992-xj-build-988350/
Tewing04 is offline
post #3 of 6 Old 07-30-2011, 10:14 AM Thread Starter
nessbran
1986 XJ Cherokee
thanks man i will give it a try!! it still seems like i would get more travel then what i am seeing. if you go more than 3 do you need longer control arms?
thanks again for the advice!!
nessbran is offline
post #4 of 6 Old 07-30-2011, 10:17 AM
Tewing04
1992 XJ Cherokee
With 4.5" coils the control arms will be long enough but at that point you will have very limited travel, so you get control arms that have a curve to them to give you a better angle so you don't hit the mount.
Tewing04 is offline
post #5 of 6 Old 07-30-2011, 11:34 AM
Luke94XJ
1994 XJ Cherokee
Get strut compressors, that's the only way I can do mine.
Luke94XJ is offline
post #6 of 6 Old 07-30-2011, 01:22 PM
sirlasvegas
I used spring compressors from harbor freight... they were like $15.
MY XJ
sirlasvegas is offline
Lift Problems... HELP!!! JerseyRepresent XJ Cherokee Technical Forum 10 06-17-2010 05:39 AM
problems associated w 5in lift yamahazinger XJ Cherokee Technical Forum 5 08-26-2007 09:26 AM
HELP!! Problems during the lift! ReconMill XJ Cherokee Technical Forum 18 08-19-2007 03:39 PM
lift problems BigwillXJ XJ Cherokee Technical Forum 1 11-11-2005 01:17 PM
Mid lift problems SpikeSpeigel XJ Cherokee Technical Forum 6 07-11-2005 01:47 PM
