Lift Parts List - JeepForum.com
post #1 of 9 Old 03-22-2012, 02:50 PM Thread Starter
mac1029
Lift Parts List
So i have been collecting parts to do my 3"-3 1/2" lift to my 99 XJ. Which desparetly needs it due to the inverted rear stock springs. So far i have...
1. Pro Comp 3" front springs
2. Pro Comp 3 1/2" Leaf Packs
3. ordering shocks (Friday)
4. ordering adjustable tracbar (friday)
5. ordering new longer u bolts (friday)
Anything i should else i should be looking at? I do know about a t-case drop or SYE if needed but i will wait and see if i get any vibrations.
Also as soon as i get more funds some new black steelies and 31" tires will be coming my way.
Any and all input greatly appreciated.
2003 WJ (SOLD)
1999 XJ Classic(5.5" Lift)
Procomp 3" leafs with RC shackles,3" Procomp springs with ACO's coil overs, RR SYE, X-Flex UCA's & LCA's, 31" XTRUS Swampers
mac1029 is offline
post #2 of 9 Old 03-22-2012, 03:22 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Lower control arms , and Extended Brake lines , Longer Swaybar links/ Disconects, Extended Bump stops . As for the T-Case Drop wait on it to see if you get vibrations . When your getting your shocks I would also get Bar Pin Eliminators
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 9 Old 03-22-2012, 03:36 PM Thread Starter
mac1029
Thanks for the input. As for the front i am going to relocate the current brake lines...The rear i had forgot about . Now i thought i could use my stock LCA (atleast for now) this is my DD and will see light wheeling while camping over the summer. And yes extended sway bar links will be orderd friday..
2003 WJ (SOLD)
mac1029 is offline
post #4 of 9 Old 03-22-2012, 03:45 PM
Tom95YJ
Tom95YJ's Avatar
Stocks LCA's will work but they are extremely weak and prone to bending. Relocating the Hard line is a way to get more length, But it is not a smart way to do it IMO. I perfer to run Extended Steel hoses in place of the rubber hoses
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 9 Old 03-22-2012, 03:51 PM
alexbl
1997 XJ Cherokee
may want to consider upgrading the steering or at least a drop pitman arm to correct steering angles
alexbl is offline
post #6 of 9 Old 03-23-2012, 08:15 AM
Tom95YJ
Tom95YJ's Avatar
A dropped pitman arm is not needed until you hit 4.5" of lift the OP wants to run 32-33" tires you can achive that by Trimming with a 3" Lift
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 9 Old 03-23-2012, 11:31 AM Thread Starter
mac1029
Thanks for all the input here. Since its my DD i and going to stick with 31" tires. As for steering upgrade i plan on that in the future. So i am just trying to make sure i have the basics for the lift.
and as we all know we just keep adding mods to improve the performace and handleing of our beloved XJ's
2003 WJ (SOLD)
mac1029 is offline
post #8 of 9 Old 03-23-2012, 04:01 PM
Tom95YJ
Tom95YJ's Avatar
IF your going to stick with 31's take a look at my build it will save you some $ over a pre-packaged lift kit.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 9 Old 03-23-2012, 05:40 PM
VegasGT
1988 MJ Comanche
You shouldnt have any trouble with your stock LCA's at that height. Ran them when I was at 3" with no troubles, even done some pretty rough wheeling (enough to break things) and had no issues. Although, they ARE very weak. I believe Ive seen 70's era fenders that are thicker metal than what the stock LCA's are stamped out of. When I took mine out I couldnt believe they hadnt buckled the second they left the dealership. They looked and felt like toothpicks in comparison to my x-flex CA's.
Id recommend longer brake lines, but you wont have problems at that height in the meantime. And your drivetrain vibration is completely dependent on how moody your particular Jeep is. They are all different, but either way, a 1 inch tcase drop should solve your issues on that even in the worst of cases. Ive had 4 XJ's that were all at 3"s at one point or another, and none of them had vibes bad enough that a tcase drop wouldnt pretty much take care of. Those years were 92 (2 door), 96, 99, and 01. The 97+ seem to have a little more trouble with vibes, but for whatever reason, my 92 was so bad it wasnt even what I would call driveable without a tcase drop. All my XJ's ive owned have had the 8.25 rear with AW4.
Good luck with the build! XJ's OWNNNN
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
Is my informal list of lift parts complete? (3.5-4" of lift not from a kit) GeologistFelix XJ Cherokee Technical Forum 1 12-28-2009 09:10 PM
My junkyard lift parts list ShantasticZJ XJ Cherokee Technical Forum 16 03-07-2009 07:28 AM
My parts list for a 3-4.5'' lift sourskittle XJ Cherokee Technical Forum 14 12-18-2007 02:21 PM
Need a parts list for lift XJ OnTheBeach88 XJ Cherokee Technical Forum 23 04-03-2007 10:26 AM
HELP--List of Lift Parts... MY00XJSPORT258 XJ Cherokee Technical Forum 1 08-19-2004 03:07 PM
