lift kit identification - JeepForum.com
post #1 of 10 Old 05-05-2011, 12:47 PM Thread Starter
Project_Sparta
need help figuring out what lift i have on this jeep i just bought.. the dealership had no idea. pretty sure though it is a RC. the shocks look white with red stickers...
1994 YJ 4.0 - Sold 2001 XJ 4.0 Stock- sold
2000 XJ 4.0 Chopped- sold. 1997 TJ 2.5 8in total lift-sold
2002 KJ 3.7 Renegade
Project_Sparta is offline
post #2 of 10 Old 05-05-2011, 12:56 PM
93gc40
More picks.. From what I can see looks Home-Brew and HIGHLY modified. Springs and shocks could be from anywhere. I seriously doubt that was lifted with a "Kit".
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 10 Old 05-05-2011, 05:47 PM Thread Starter
Project_Sparta
Here are some more pics
ForumRunner_20110505_194501.jpg   ForumRunner_20110505_194521.jpg   ForumRunner_20110505_194556.jpg   ForumRunner_20110505_194607.jpg
post #4 of 10 Old 05-05-2011, 05:55 PM
Kettles
Looks all "custom" home brew stuff. Coil springs could be from anywhere, the rear is clearly a bastard pack (with a bad shackle angle, and they didn't bother to remove the old packs spring clamps), and there are drop brackets up front (i hope they are store bought). The design was thought out enough to have drop brackets and custom (assumed proper length) control arms and steering, a trussed (to some degree) front axle, relocated track bar, etc. Quality, I can't say though. If it were mine I would replace anything with a apparantly bad weld asap. I would inspect the steering as it looks custom and possibly by the same welder as the control arms (the weld on the upper control arm looks atrocious).
EDIT:
Looking at the control arms more, The bushing sleeves and all that look professionally done (or machine done), the bad weld is in the middle like it was an adjustable arm and they welded it solid, or cut the arms because they were to long or something, I don't know. Either way the weld scares me, and makes you wonder about other things.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #5 of 10 Old 05-05-2011, 06:11 PM Thread Starter
Project_Sparta
were the front sway bars would connect to were also cut to allow movement of the steering. With everything being custom im not sure were to even start at replacing things. im already having to replace a lincoln locker in the rear, and the a/c compressor was set up for onboard air.
post #6 of 10 Old 05-05-2011, 09:19 PM
rugsucka
I bet the rear leaf is stiffer than... well I hope you fillings are in good.
The welds look like booger stick welds - probably OK for strength, but pretty ugly looking - could have at least smoothed them a bit with an angle grinder.
Pay much? I'd make sure the alignment is adequate and find a local jeeper to look it over with you to ID the good bad and ugly.
If that's your young lady you have a pretty good reason to ensure you won't death wobble yourself and her into an accident.
I'd wheel the piss out of it - you have a unique rig that many would over. It's probably built by someone who knew what they were doing, but lacked some welding skill and finesse.
rugsucka is offline
post #7 of 10 Old 05-05-2011, 09:36 PM
Brookhart63
Sweet rig for sure. Whoever it was knew what they were doing but maybe didnt care about looks? Ugly welds hold but they are well......ugly. Custom rig that needs to be wheeled. Hard! Good luck mate!
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #8 of 10 Old 05-05-2011, 09:59 PM
Kettles
As a welder myself, I disagree with the two previous posters saying that the ugly welds hold. The question is though, what are those welds doing.
If that is a threaded joint for adjustability (what it looks like given the overall construction, looks very similar to IronMan 4x4 Fab's arms) then 2 things. 1, I cant figure out why it is welded, and 2, the welds are pretty much pointless, unless they couldn't find a jam nut!?!?!. And it shouldn't be anything to worry about.
If its not (or more so no longer) a threaded joint and those welds are in any way structural, I would cease all driving of the jeep immediately.
My best guess (being nice to the PO) was he had those arms without drop brackets, got drop brackets, and couldn't adjust the arms short enough with the jam nut, so he ditched the jam nut and welded it instead using a cheapo stick welder he doesn't know how to use. If that is the case don't worry about it.
Other that that, I am not a fan of the rear bumper, but I love the chop job. I always had a soft spot for chopped cherokees.
_=====o000o
Kettles is offline
post #9 of 10 Old 05-06-2011, 10:29 AM Thread Starter
Project_Sparta
Well the rear is really not that stiff... but then again i came from a 94 yj that everytime i hit a pebble i felt it.
and not really,,, they were asking $5k for it, i pretty much traded straight up with my YJ.. I really didnt want to but my tranny, water pump, oil pump and a list of other things were going out.,
And my daughter loves my jeeps she always loves riding with me. but i will take it to a shop this week and have someone look at everything. Thanks
post #10 of 10 Old 05-06-2011, 10:32 AM Thread Starter
Project_Sparta
Thanks I will look into it. I was going to buy this XJ about 3 years ago but someone beat me to it, but when i seen it for sale again I jumped on it. The owner of the lot said the guy who had it beat the piss out of it, that he had to replace alot of front end parts... so I probably should go get a alignment check.
XJ D44 identification? 9mmprn XJ Cherokee Technical Forum 9 08-16-2011 08:03 PM
Suspension Lift component identification kdizzle79 XJ Cherokee Technical Forum 11 10-19-2010 11:43 PM
Need Engine identification help! dkroll MJ Comanche Technical Forum 9 06-04-2008 12:37 AM
Trac-Lok identification quafiediff XJ Cherokee Technical Forum 4 01-18-2006 08:15 PM
4.0 - Identification Help MuddyMules XJ Cherokee Technical Forum 2 10-22-2004 09:06 PM
