lift kit - JeepForum.com
post #1 of 28 Old 04-25-2012, 01:56 PM Thread Starter
97cherokee1997
lift kit
Hey i have a block lift kit and i was wondering if i dont replace the shocks will it death wobble. Its a 97 jeep cherokee sport and if i do what kind of shocks should i get its a three inch lift kit.
97cherokee1997 is offline
post #2 of 28 Old 04-25-2012, 02:22 PM
whitexj98
short no, but that dosent mean it wont! And 3 inch blocks will wreck your leafs and lead to more problems, I suggest you do some researching .
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #3 of 28 Old 04-25-2012, 02:29 PM
donthelegend
Shocks don't generally play a role in DW, but if you are going up 3" I would highly recommend replacing the shocks with some that are made for 3" of lift. Brand is up to your budget and how picky you are about ride quality, but OME and Bilstein are both high quality shock manufacturers.
If you are talking about putting a 3" block under the rear leaf springs, I'd strongly recommend against it. Blocks are not good on Cherokees in general, but a 3" block on stock leaf springs would be especially bad.
donthelegend is offline
post #4 of 28 Old 04-25-2012, 02:33 PM Thread Starter
97cherokee1997
Ok what should i put on the back then
post #5 of 28 Old 04-25-2012, 02:36 PM Thread Starter
97cherokee1997
And i meashered my front blocks because they looked like a 2 inch lift and i bought them for a three inch lift and they meashered 2 1/4 inches so should i get 2 inch blocks for the back or a new leaf
post #6 of 28 Old 04-25-2012, 02:38 PM
mountainjock
1988 XJ Cherokee
New leafs, block are a no-no!
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
post #7 of 28 Old 04-25-2012, 02:58 PM Thread Starter
97cherokee1997
Every body i no says that with a add a leaf u have to get a 6 inch lift add a leaf to get a 3 inch lift is that true
post #8 of 28 Old 04-25-2012, 03:28 PM
donthelegend
Go read here: http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/
Then do some basic searches for the following: Add a leaf, lift block, bastard pack, lift shackle, spacers.
Read some of the threads about what people have to say about them. Then form an informed opinion about your needs, budget, and what you are trying to accomplish based on everything you've researched.
Then ask any more specific questions you may have about a particular setup.
post #9 of 28 Old 04-25-2012, 03:36 PM
Callelle
1997 XJ Cherokee
You should put 2, 2 inch blocks on top of each other and rock out at 4 inches!
Callelle is offline
post #10 of 28 Old 04-25-2012, 03:37 PM
jeepster383
Whats so bad about the blocks?
jeepster383 is offline
post #11 of 28 Old 04-25-2012, 04:13 PM
whitexj98
They increase leverage on the leaf packs which leads to axle wrap under tourqe which leads to fast failing leafs or worse they snap!
post #12 of 28 Old 04-25-2012, 05:19 PM
jeepster383
Oh okay i guess that makes scense
post #13 of 28 Old 04-25-2012, 05:58 PM Thread Starter
97cherokee1997
So in the back i should use a add a leaf
post #14 of 28 Old 04-25-2012, 06:07 PM
jeepjunkymike
blocks in the front? on an xj,, do you mean coil spacers?
lift it,,,,fat girls cant jump
jeepjunkymike is offline
post #15 of 28 Old 04-25-2012, 07:50 PM Thread Starter
97cherokee1997
Ya i mean coil spacers
