Lift Concerns - JeepForum.com
post #1 of 20 Old 01-21-2014, 05:16 PM Thread Starter
jeepjunkie97
Lift Concerns
I'm looking at the Rubicon Express 3.5" super-ride lift kit. With the transfer case vibrations would it be ideal to get a SYE or get a drop kit for the case? Also if i were to run Mamba Offroad alloys (15x8 4.5 BS) with a 31x10.5x15 tire would it rub at all? i read somewhere that the 97+ have smaller wheel wells and may require trimming? Thanks!
jeepjunkie97 is offline
post #2 of 20 Old 01-21-2014, 06:57 PM
rugsucka
-get a SYE if you want the ideal option.
-you won't rub the LCA but you will probably rub the fenders a bit if you offroad it - not likely just driving to the mall
-trimming is easy and can be done well without looking like a hack job
rugsucka is offline
post #3 of 20 Old 01-21-2014, 07:15 PM Thread Starter
jeepjunkie97
Didn't plan to do extreme off roading with it. Where would be a good place to shop for new driveshafts?
post #4 of 20 Old 01-22-2014, 03:46 PM
AmbuGrl
AmbuGrl's Avatar
tatton ds are great or but a used one and have a shop cut/balance it foryou.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #5 of 20 Old 01-22-2014, 03:52 PM
Moto4x4
You should look into driveshaft/sye combos, you can save some money. I went with Adams driveshaft, I liked it a lot the entire time I owned my jeep!
Moto4x4 is offline
post #6 of 20 Old 01-22-2014, 04:00 PM Thread Starter
jeepjunkie97
Hmm I'll look into it. How much lift did you have with it as well?
post #7 of 20 Old 01-22-2014, 04:04 PM
Motorcharge
Lift it then see if you need an SYE or TC drop. Usually don't need them til you get over 3.5" but 97+ XJs are a little more funny about it needing it. You really don't need to replace the driveshaft at 3.5" unless you end up needing an SYE. Even then a small TC drop should be fine unless you want to spend the extra money. If you're not wheeling a lot or anything big then there's no real sense in spending the extra money on the SYE and DS.
As for the tires, if you change your bump stops (which you should any time you change suspension and tire sizes) then you shouldn't rub anything.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #8 of 20 Old 01-22-2014, 04:21 PM
mschi772
1997 XJ Cherokee
I think at 3.5" you can still get away with using an XJ front driveshaft for the rear with an SYE.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #9 of 20 Old 01-22-2014, 07:23 PM
um7267
he also could just get a driveshaft out of a pre 97, if he wants to go that route
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #10 of 20 Old 01-22-2014, 07:29 PM
bangarang
1981 CJ8
I guess it would depend on the jeep and the vibes it gives but i would think that a 3.5" lift that will settle a few more fractions wouldnt need an sye or a drop. but like i said it all depends on if theres vibes or not.
bangarang is offline
post #11 of 20 Old 01-22-2014, 10:15 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Yup, this is the setup I had in my old '96. SYE and stock front driveshaft in the rear on 3"-3.5" of lift.
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #12 of 20 Old 01-23-2014, 11:38 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Technically, I'm at 4.5" in the rear, but weighed down. I have no issues without an SYE.
D3<!L!>3D
S8NNG8 is offline
post #13 of 20 Old 01-24-2014, 03:22 PM
Moto4x4
5.25" but it was a tj.
I'm going 4.5" on my Cherokee but will be going the same sye/driveshaft route
Moto4x4 is offline
post #14 of 20 Old 01-24-2014, 03:30 PM
Mike934
Ima cheap ***. Stock jeep came with a d35 (longer shaft). I swap on a Yj yoke that allows higher angles for 20 & upgrade to a c8.25. (Longer. Pinion). So at my 3-3.5" I don't get vibes when the pinions set and never drop the shaft
Funny thing is I've got a hack n tap and a full sye in the garage hahaha.
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #15 of 20 Old 01-24-2014, 04:48 PM
DunmerBoy
I'm at 3 inches with a 98 and no vibes and threw 2 hockey pucks per coil spring and never rub on 31s
COTM October 2014
DunmerBoy is offline
