Lebaron Hood Vents & TPS - JeepForum.com
post #1 of 17 Old 03-16-2012, 05:06 PM Thread Starter
billabongopblue
To inform everyone who has or is thinking about Lebaron Hood Vents, you may need to reconsider.
Since they have been installed on my 96 Classic in June 2011 I have been through 6 TPS sensors. Yes, 6. Thankfully they are under warranty, but i will be soon thinking of something to fix this issue for the future.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #2 of 17 Old 03-16-2012, 05:23 PM
GtiKyle
Ok... So what's the correlation ?
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #3 of 17 Old 03-16-2012, 05:32 PM Thread Starter
billabongopblue
The correlation is that the sensor gets wet and needs to be replaced.
post #4 of 17 Old 03-16-2012, 08:38 PM
Azzy
The TPS sensor is a bit sensitive to moisture. I wonder if there is anything that can be done about that (like say, drip pans). Wonder how much dilectric grease would help.
Have you guys ever pulled a bad one apart? its a strip of plastic, with 2 contacts. They usually wear out a spot in the middle from the throttle staying in one small area.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 17 Old 03-16-2012, 09:18 PM
GtiKyle
Hmm, yah i have a hard time believing in less than 1 year that 6 could go bad JUST from having hood vents. Did you keep exchanging these sensors "under warranty"? Where from?
How were you sure that the TPS was the problem?
Build thread :
GtiKyle is offline
post #6 of 17 Old 03-17-2012, 12:44 AM
SlimGoaty
SlimGoaty's Avatar
1997 XJ Cherokee
If your getting your TPS from autozone or napa or something your already dealing with an inferior sensor. Anytime your buying a sensor for your jeep its highly recommended you buy OEM from the stealership.
That said, I would believe you. Both times I cleaned my engine bay the TPS went bad, and I have had multiple friends have theirs go bad after water under the hood. This is a big reason I'm not jumping on the hood vent band wagon until I find a good way to make drip pans or silicon a lot of stuff under the hood.
97 XJ 4.0, AW4, 231, RE 5.5, Tom Woods DS, AA SYE, 35x12.50 KM2,
Upgraded Harness, PIAA bulbs, Rustys Tie-Rod, L&L Fab bumper,
Quadratec 9500i Winch, Aussie locker, 4.88's
SlimGoaty is offline
post #7 of 17 Old 03-17-2012, 01:15 AM
robsjeepxj
I've had the LeBaron vents on my jeep for at least a year, driving in rain, gotten snow on the motor and haven't had a single issue at all with sensors going bad. I seriously doubt you got 6 bad sensors, seriously.
robsjeepxj is offline
post #8 of 17 Old 03-17-2012, 01:33 AM
DerMeister
Did you grease them? Also whered you get them?
DerMeister is offline
post #9 of 17 Old 03-17-2012, 05:17 PM
Azzy
Knock on wood, but my Advance TPS has been trucking along fine for a year... Those Chinese fellows get something right out of the factory once and a while.
Azzy is offline
post #10 of 17 Old 03-20-2012, 11:58 AM
dcorn
I've had the RunCool vents in my hood for at least 3 years, which let in a ton of water and snow and whatever else. Still have the stock TPS in there.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #11 of 17 Old 03-20-2012, 12:11 PM
GtiKyle
It's rained nonstop here the last few days, and i see that my TPS is directly in the path of the vent...so I'll be updating if i have issues.
Build thread :
GtiKyle is offline
post #12 of 17 Old 03-20-2012, 12:23 PM
Metro55
It rained like nuts here last night..I went out and started my Jeep about 2 hours after and it was fine. I have the same vents at GtiKyle..
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #13 of 17 Old 03-20-2012, 12:28 PM
Metro55
For what it's worth.. it probably wouldn't be to hard to make a bracket that mounts to the existing TB bolts, and then make something that comes up and over the TPS to block it from the downfall of water..
.,,_____,====,
Metro55 is offline
post #14 of 17 Old 03-20-2012, 04:10 PM
christianbe
1992 XJ Cherokee
I just covered my TPS up with a small piece of aluminum flashing that directs anything coming through my vents away.
christianbe is offline
post #15 of 17 Old 03-20-2012, 10:07 PM
Metro55
I just rigged this up tonight.. uses the throttle body bolt locations...this should suffice...and just **** ****s I made a MAP cover too
.,,_____,====,
Metro55 is offline
LeBaron hood vents vs. water Finallyajeep XJ/MJ Cherokee Non-Technical Forum 19 01-19-2013 08:39 PM
Not your typical LeBaron hood vents... 00BlackdOut XJ Cherokee Technical Forum 27 03-28-2008 05:52 AM
LeBaron Hood Vents UKJeepThang XJ Cherokee Technical Forum 9 08-25-2007 08:39 PM
LeBaron Hood Vents LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 5 02-19-2007 11:28 PM
