leaf clips - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > leaf clips
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 07-17-2009, 08:46 AM   #1
nakedron
1997 XJ Cherokee
leaf clips
i had a lift put on about amonth ago and i started to hear a loud metal to metal sound. lastnight i put in the air to change the oil and all my clips that hold the leafs together are broke. there just thin cheap clips i was wondering what some of yall might use? i run 35" tires so i was told that i might be wraping the springs. not sure on that becuase they should have held.
IF FOLLOWING, MUST HAVE FLOATION DEVICE!!
nakedron is offline   Reply With Quote
Unread 07-17-2009, 09:02 AM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Many auto parts stores and any spring and suspension shop will have leaf spring clips. They are also called rebound clips. You can find them on-line also. Print out the picture in case the counterman is a little "slow".
http://www.huskyspring.com/main.taf?cat=160
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 07-17-2009, 09:07 AM   #3
XJH-007
Good call. I need to start doing that. I nearly went to blows with some NAPA Counter Jockey trying to explain I needed Control Arm Bushings to him...
FYI........NAPA calls them..."Chasis Isolators"
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Unread 07-17-2009, 09:29 AM   #4
nakedron
1997 XJ Cherokee
i still dont think that they will be thick enough
