Lcog thoughts? - JeepForum.com
post #1 of 27 Old 02-23-2013, 10:46 PM Thread Starter
Luke95
Lcog thoughts?
I'm a fan of it, what's your views on it?
Sent from my black box in my silver pos box
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #2 of 27 Old 02-24-2013, 04:38 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
The lower the center of gravity of a vehicle is, the more stable it will be.
Lower can be a benefit in steep terrain, off-camber, and high-speed maneuvering situations, or a detriment in marshes, bogs, mud, and water crossings.
Build your rig to suit your typical wheelin conditions.
***Chris***
chris87xj is online now
post #3 of 27 Old 02-24-2013, 06:44 AM
ibjeepin95
It's gay.
ibjeepin95 is offline
post #4 of 27 Old 02-24-2013, 06:49 AM Thread Starter
Luke95
Originally Posted by ibjeepin95
It's gay.
Like your civic .!..!.
I like the stability in rocks. But 8 inch lifts with 33 lol
Luke95 is offline
post #5 of 27 Old 02-24-2013, 08:08 AM
Motorcharge
If you're even remotely serious about crawling rocks lcog is the way to go. If you're even remotely serious about wheeling outside of mud then it's the way to go.
http://www.cherokeeforum.com/f67/low...24-12-a-32980/
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #6 of 27 Old 02-24-2013, 08:30 AM Thread Starter
Luke95
I know about I wanted to see way you all liked?
Luke95 is offline
post #7 of 27 Old 02-24-2013, 08:37 AM
rugsucka
LCOG will bite your balls climbing ledges in the rocks, and all but requires a belly pan, and lockers are a must to do the job when dragging your junk around.
I'm at 5" and happy with the lift, and will run it at this height beyond 33's into 35's when the time is right. Any bigger rubber and it's axle swapping time.
I don't feel I'm excessively lifted or necessarily LCOG - it's just right for some mud, and mostly crawling.
I also don't judge peoples builds unless they make absolutely no sense - 10" lift and short arms type stuff.
rugsucka is offline
post #8 of 27 Old 02-24-2013, 08:41 AM
ibjeepin95
Your so jealous I have a DD Civic. Don't lie. At least I can go places when my XJ is down. Wear and tear? What is that?
post #9 of 27 Old 02-24-2013, 08:51 AM
Kevin108
LCOG: it's as overdiscussed and misunderstood as flex, horsepower, lockers and sequestration.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #10 of 27 Old 02-24-2013, 08:52 AM Thread Starter
Luke95
Passat .!..!.
But I dunno man your Xj is not to bad
Luke95 is offline
post #11 of 27 Old 02-24-2013, 09:18 AM
ibjeepin95
Well, here are my true thoughts on LCOG.
1. I hate this "LCOG" term. With a mad fawking passion. Having a low center of gravity shouldn't be termed. With that term being used, it feels more like a "fad". Which I hate.
2. A lower rig has a lot of advantages. It obviously keeps your weight low, keeps the weight more centered on steep climbs, easier to keep suspension geometry at better angles, and you can achieve just as much FLECKS as anything else if set up properly.
3. It's main disadvantage is your break over angle. lots of skids, a good transfer case skid/ belly skid, and frame stiffeners and you can make it "slide" over most things your break over angle would usually prevent.
4. Don't think that a low center of gravity setup is cheap. Because it isn't. Sure, anyone can cut fenders and fit 35's on 3 inches of lift. The problem is, it isn't going to work well just like that. There are a billionty factors to make it work well. Inner fender clearancing, bump stops, shock lengths, cleancing everything under your XJ to make skids flat, etc, etc, etc. I could go on and on. Basically, one of the best things to do to build a low rig is to learn to fab and build things yourself. That way, you aren't limited to what things will work and what won't.
post #12 of 27 Old 02-24-2013, 09:21 AM
Texsun
I am right at 4" of lift and love it... I would say run what suits you instead of choosing what is "cool"
Texsun is offline
post #13 of 27 Old 02-24-2013, 09:24 AM
ibjeepin95
4" over stock or 4" springs plus axle brackets that add to your height?
post #14 of 27 Old 02-24-2013, 09:59 AM Thread Starter
Luke95
I went with 3 inches of lift because of what I read and could afford viably.
I then compared the rustys coils 150 or 180 lb didn't really like them not enough, went to the rubicon express because of the 230 lb rates. I liked it because I will be towing a boat and such. Next I went and decided 10 inch shocks would be good for flex and found a set of Good ones from naxja rancho9000s made some upper mounts and called it good.
Next I'm doing control arms with double hiems and 33 tread wrights.
Skids I plan on doing are a t case skid and a gas tank skid. Simple and effective.
One note I should throw in is exhaust I went with a glass pack and down pipe after this
Luke95 is offline
post #15 of 27 Old 02-24-2013, 10:13 AM
Texsun
4" springs and 4" leafs ontop of the brackets/mounts so its right at 5.25" over stock.
Texsun is offline
