Late 90s Cherokee Purchasing Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Late 90s Cherokee Purchasing Questions
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-19-2014, 03:00 PM   #1
MikeW89
I'm looking to buy my first Jeep and I'd like to get 1990s Cherokee. I've found a number of them in my price range with anywhere from 85k to 180k miles on them. My question is what kinds of parts should I be on the lookout for that break on older Cherokees to make sure they have been replaced? One of the best options I found is a 1998 Cherokee with 90k miles, but it is listed at over $1,000 above the KBB (they want $6,000 vs KBB value of $4,750). It seems well-maintained, but I don't think it could be worth that much over the KBB. What parts should I be asking about that might or might not have been changed to influence that price?
Thanks!
MikeW89 is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 04:02 PM   #2
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
There really isn't a ton of stuff that routinely breaks on these things - it's a big part of the reason why we love them!
Find out what they have as far as maintenance records, ask them about the last time it had brakes, a tune up, trans / transfer case / differential fluids, etc. The seller's responses to questions like that should give you a good idea of how well they really took care of it.
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
NJ F-Body Owners Association
Tru2Chevy is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 07:10 PM   #3
ECL
Sounds high but if it's rust free and runs good, make an offer.
I like my 98. I've had it 6 yrs. The coil died once and stranded me. Ground strap on the engine corroded away and gave me fits. A/C has never been right. Other than that, just routine stuff - tune ups, brakes, tires, exhaust.
It the upgrades you want to do that hurt financially the most!!
ECL is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 12:16 PM   #4
shooptube
1997 XJ Cherokee
- Justin
Except the center console latch!
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 02:17 PM   #5
Motorcharge
1991 MJ Comanche
Blue book value is meaningless and XJ's typically run high in VA. For the last few years anyway.
These new sig limits suck. Thanks a lot Canada.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 06:25 PM   #6
amerbritcan
Mine lasted fine for 15 years before I owned it. Lasted about 15 minutes into my ownership (ok maybe a couple hours.
Was a real "well, f***" moment hahaha
99 XJ, 4.5" RC cheapo lift. Desperate for more tire.
amerbritcan is offline   Reply With Quote Quick reply to this message
Unread 11-22-2014, 03:09 PM   #7
rjbruzan
The only suggestion I have is get the best one out there that you can afford.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote Quick reply to this message
buying a jeep , buying advice , cherokee
