Kevin108's 2000 XJ Build - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Kevin108's 2000 XJ Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-19-2010, 10:13 PM   #61
Kevin108
Originally Posted by Smittyman View Post
Clean look with the Sirius!
And... PICS! Before and After 2" shackles
I haven't taken and pics or measurements yet. I had two old computer monitors I finally dropped off at Goodwill today and I've yet to bring in the 40 lb bucket of cat litter and 3 boxes of cat food in the back.
Once I get the crap emptied out, I'll see what the tape measure says. Before I ordered the shackles, it was sitting 1˝" low in the back. The shackles are adjustable for 1˝" and 2" but I went ahead and bumped them up to 2" because from what I know about shackles, they'll only actually give about half that much lift.
We'll see. Maybe tomorrow.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2010, 02:18 PM   #62
Vassago
dude look at the sagging leaf spring! change that!
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f177/...lding-1575841/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote Quick reply to this message
Unread 01-20-2010, 04:43 PM   #63
Kevin108
I had the other side jacked up or something when I took that pic. They're really not that bad!
Unread 01-20-2010, 04:47 PM   #64
lk123
1993 XJ Cherokee
looks nice, but not so fun something i gotta do hopefully this summer
My 93xj build4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2010, 10:27 PM   #65
MC_wk
2007 WK
This will definitely help when I go to put on my shackles on Friday.
You have a very clean lookin XJ. And I'm jealous of your Aussie.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline   Reply With Quote Quick reply to this message
Unread 01-21-2010, 03:14 PM   #66
Kevin108
Yeah, stock is boring but this is primarily a daily driver so I'm trying to keep from getting carried away. I'm going to add some skid plates and rock rails and that should be it until I need tires.
Good luck with your install. Make sure you've got a good 4' or so pry bar to wiggle the springs around and maybe a few pieces of scrap 4x4 to help out.
My rig does have some missing paint but it's from rocks thrown on the interstate and people that don't know how to parallel park. Everything else I own is rough so I'm trying to keep my XJ nice.
I'm really anxious to get a feel for what this Aussie will do and how much it will help make up for the fact that I'm running street tires. My club's got a trail run on Jan 30th so I'll know soon enough!
Unread 01-21-2010, 08:56 PM   #67
Kevin108
The locker came today. I was going to put it in tonight but I drive over and use my Dad's garage for my projects most of the time and tonight he was finishing up a landscaping trailer so I'll go Friday night.
Unread 01-23-2010, 06:06 AM   #68
Kevin108
I've put in a Lockright before and because in my truck a mild TBI 350 + 35s + 250,000 mile-old 10-bolt = randomly exploding spider gears and a failed Lockright, I'm very familiar with how to disassemble the guts of a rear diff.
The Aussie Locker took 2˝ hours to install in my XJ. The only part that was in any way tricky was getting the passenger side C-clip in and the pinion shaft reinstalled. A big blob of bearing grease held the C-clip where it needed to be while I used a flat screw driver to put it around the axle shaft. It took a quite a bit of wiggling around the axle shaft via the wheel to get the cap to seat over the last C-clip once it was installed. The only other difficult thing was filling the diff once everything was back together. I've really got to find a trick for that.
My impressions so far are compared to my experience with a Lockright in a Silverado with an 8' bed and 35s. I think the longer wheelbase, wider track and larger tire size played a big role in making the locker feel invisible on the street for that rig. With it, there's no such thing as a sharp turn. It literally has approximately the same turning radius as a school bus, for whatever reason. Also 35s turn a lot fewer revolutions to cover the same distance as 29s. That led to a lot less ratcheting of the locker.
No weird clicks or bangs. Maybe a little bit of understeer but I know I'll be used to it in a couple days. It'll see trail use a week from today.
Unread 01-25-2010, 05:39 PM   #69
Kevin108
Today after work I rebuilt the rear divider I'd made a while back to keep everything from sliding around. I've also got 4 D-rings I want to add to the floor to be able to really secure everything. The divider won't be fastened down like some of the other storage solutions you've seen but it will be incorporated inside the tie-down configuration with the installation of the new D-rings.
The layout of everything is so a cooler fits between the tool box and the wheel well like before but I added a couple other pieces so nothing slides even when the cooler is out. It's also much lower than the original version to facilitate easier removal of the toolbox and the cooler. Everything except the soft-sided lunch box, the bottle jack and the 12v air compressor fit into the toolbox but I didn't fool with cleaning things up yet.
Now just to prime and paint!
*edit* - I went to mix up my primer and apparently it froze and cracked the plastic bucket. Plus the battery for my drill to mix it with is still dead from my last junkyard run. Guess I'll have a beer and wait on it to charge.
Unread 01-26-2010, 07:34 PM   #70
99jeeper
Lol...nice I had to fix my exhaust the same way.
99jeeper is offline   Reply With Quote Quick reply to this message
Unread 01-26-2010, 09:12 PM   #71
Kevin108
I bought some fresh primer today. I primed and painted tonight. It'll take me tomorrow night to get the final coat on though.
Unread 01-26-2010, 09:49 PM   #72
coalregionXJ
1989 XJ Cherokee
they have dingaling in VA??? i live 5 mins from the town thats makes it here we call it pottsville piss water lol , i love lager!
89 XJ 4.o ax15
6.5 inches of lift
lockers front and rear
32's mastercraft courser mt's
homemade snorkel
"hold my beer and watch this
coalregionXJ is offline   Reply With Quote Quick reply to this message
Unread 01-26-2010, 10:07 PM   #73
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
I remember back in '99 it finally made it's way down to Frederick, MD and all the places were advertising the "NEW BEER"... It's one of my favorites I miss PA
koolaid5 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2010, 11:05 PM   #74
Kevin108
Since it's been cold I've really enjoyed the Black and Tan but we had a little throw-down Saturday and I still had a couple cans of the plain jane left that I killed waiting on paint to dry. I wish I could get straight Porter from them. It would probably be as good as everything else they make.
Unread 01-26-2010, 11:22 PM   #75
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Did you know that Sam Adams makes a limited edition beer that is 27% alcohol called Utopias? I learned about that on my cruise during a beer tasting Also learned that Guiness only has like 4.1%. Anyone want anymore fun beer, martini, or wine facts
