Kevin108's 2000 XJ Build - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Kevin108's 2000 XJ Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-03-2010, 03:21 PM   #46
Kevin108
Originally Posted by srmitchell View Post
Save the headache.
My aj's sliders are perfect, and the install was super easy.
I can build them for myself* for about half what AJ's cost but for the time, I keep looking at them.
* Building for myself with material I pick up locally removes the cost of labor and shipping. I can't make you a set for half. For the time, materials and shipping, AJ's price is great.
Originally Posted by Smittyman View Post
Are you happy with your tow hooks?
They should have come black like I ordered them. I am not satisfied with that. Nor the fact that the keepers rusted as soon as they were exposed to moisture. As far as the quality of the brackets, the welds looked great the material was beefy. I haven't had to use them so far though.
Originally Posted by jsmiddleton4 View Post
Nice Cherokee.
Thanks!
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 01-03-2010, 09:22 PM   #47
Smittyman
That is pretty lame with the paint and the keepers rusting But the beefyness is a plus! Thanks man
Patriot Blue Y2K XJ. Big plans, small wallet.
http://www.jeepforum.com/forum/f22/00-xj-sport-daily-driver-build-thread-908084-new/
Smittyman is offline   Reply With Quote Quick reply to this message
Unread 01-03-2010, 09:43 PM   #48
srmitchell
The paint on my hooks lasted 2 runs, before I bashed it off.
I understand about the rails. Building anything isn't a simple option for me.
I work on Mopars
srmitchell is offline   Reply With Quote Quick reply to this message
Unread 01-03-2010, 10:13 PM   #49
Smittyman
Sounds as if a couple coats would be recommended before install... Hmm.. And bashed it off
Unread 01-04-2010, 06:34 AM   #50
Kevin108
I'm a carpenter by trade so most of the skills overlap with metal working. I have never welded anything before so I'll get it stuff tacked together then get a buddy to finish off the bead.
Unread 01-04-2010, 07:50 PM   #51
Kevin108
Woohoo, I fixed my CEL!
It wasn't on when I got it but shortly afterward the light came up with the code for the evap enviro-BS so I just ignored it. A few days ago poking around under the hood I noticed I had knocked loose a vacuum line under the air box. I plugged it back in and tonight my CEL went off.
Unread 01-10-2010, 09:17 AM   #52
Kevin108
Just ordered some Rough Country Jeep XJ Adjustable Shackles to deal with my rear sag. I know it's a stop-gap measure but I'm not interested in messing with spring packs right now.
I'm also ready to order my rear locker. I've got a PM in to Northridge4x4 to see if I can get any help on the price. I missed the 10% discount they had going at the end of 09 but even without that they still have the best price.
Unread 01-11-2010, 06:25 AM   #53
Kevin108
I resubscribed to Sirius the first of the year. My current plans are to drill a small hole in the bottom of the ash tray to run the wires through. That way the unit will be invisible and removable. I'll just have to remember not to put any really small screws loose in there.
I'm also going to make a custom mount that rusts inside the open ash tray. Here's my prototype. The first one I made was flat and you wouldn't read the display. I put an angle on it with a coping saw when I got home, so this looks rough but it works great so far. I do need to test for clearance on the shifter still, so this may not work. More pics when it's finished.
Unread 01-11-2010, 02:33 PM   #54
BRad704
Nothing to see here...
BRad704's Avatar
I'm glad to see that i'm not the only one that fabs stuff up in wood first!
BRad704 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2010, 03:59 PM   #55
callmebobbyt
1995 XJ Cherokee
good stuff man, from a few miles away in vb. will continue watching the transformation.
1995 XJ 2 dr. Flat Black trimmed in Bedliner
6.5" Rusty's Short Arm Spring Pack Kit
JKS Quicker Disconnects
33x12.5 "Richard" Cepek FC-II on 15x8 American Racing Black Steelies
SYE Kit with Tom Wood's Custom Driveshaft
HPD30 4.10 LockRight
C8.25 4.10
callmebobbyt is offline   Reply With Quote Quick reply to this message
Unread 01-11-2010, 04:25 PM   #56
Kevin108
The finished product will be wood too.
3 screws is overkill but it also helps distribute the force of the button mashing across the thin plastic I countersunk them into. It's been sanded and painted. I'll probably get one more coat on it tonight and hopefully get it installed tomorrow.
Unread 01-19-2010, 09:32 AM   #57
Kevin108
Sirius and the RC 2" lift shackles are installed but our cable modem died so I'm not sure when I'll get pics and info up. Hopefully we'll have a new one today but I don't count my chickens before they're hatched. The Aussie Locker for the rear will be here this week as well.
Unread 01-19-2010, 06:31 PM   #58
Kevin108
Sirius is almost finished. I'm going to add another cigarette lighter plug inside the dash so the power wire is completely invisible. I've already run the wire, so all I have to remove is the center dash panel. The wires are run carefully under the carpet and around all the shifters. Here's the pics of the installation.
Unread 01-19-2010, 07:13 PM   #59
Smittyman
Clean look with the Sirius!
And... PICS! Before and After 2" shackles
Unread 01-19-2010, 10:05 PM   #60
Kevin108
First I want to thank everybody that gave me info in the thread http://www.jeepforum.com/forum/f11/a...4/#post8699116 You guys made this installation a breeze!
Rough Country includes no instructions at all - just a box full of shackles, hardware and other pieces you won't understand until you remove the factory shackle. This kit will leave you with extra parts - two washers and two nuts. It takes longer to get the jack stands setup optimally than it does to actually install the shackles.
Side by side with the factory shackle. The two bushings pushed in by hand and then I used a vice to press in the sleeve although I'm sure you could tap it in easily with a hammer.
Let the PB Blaster do its thing. My bolts weren't too bad.
The upper nut is made into the frame and can be challenging to get a bolt into. It was infinitely easier to have someone else pry on the springs while you lined up the shackles just so to insert the bolts.
If you have a Curt rear hitch, you can't put the bolt in on the drivers' side with the nut on the outside. This results in the nut making contact with the tail pipe and rattling occasionally, especially at idle. The bolt head is thinner than the nylock nut and would likely clear the tail pipe but the hitch blocks you from being able to insert the bolt the opposite way.
My solution was to cut the factory pipe just behind the last hanger and replace it with a bolt-on turn down from the parts store.
The new turn down tapers down in front of the shackle instead of behind it. I hope they don't give me a hard time on this when I get it inspected as even the factory turn down didn't extend beyond the body.
