Kevin108's 2000 XJ Build - Page 32 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Kevin108's 2000 XJ Build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-29-2013, 09:36 AM   #466
tnc22
It would be a bummer to see you without a heep. You are a source of inspiration and good ideas for many others.
Keep up the good work!
tnc22 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2013, 11:38 AM   #467
Kevin108
Wow... Thank you!
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2013, 12:03 PM   #468
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Originally Posted by Kevin108 View Post
It's not about the one wreck but total amount of frustration. The overall unreliability, poor design from the factory, major failed components, electrical gremlins, etc. that I've been fighting the last 4 years has me of a mind that this will be the one and only Jeep I ever buy.
Buy a better one next time.
Also, sucks to see but glad you're fixing it.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 07-29-2013, 03:22 PM   #469
Kevin108
Other than getting a 99 instead of an 00 so you have the HP 30 and don't have a cracky head, I'm not sure how you get a better one. This thing was cherry when I bought it. It just hit that magic 10-year fall-apart time in my ownership. Just because I understand it, it doesn't aggravate me any less.
The gauges / no_bus I can't fix are stock. The blower motor resistor was a stock component whose failure was poorly thought out. The wiring I have to keep plugging back into the blower motor is stock. The child lock-out switch I had to bypass to return control function to the passenger doors? Stock. The 0331 head that cracked from overheating just briefly one time? Also stock.
Unread 07-29-2013, 04:44 PM   #470
Luke95
I have to say I love my 98
I <3 rockrash
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2013, 11:13 PM   #471
AKIQPilot
I agree. I remember reading this thread last year right after I joined the forum. I thought to myself: "hey, this guy is pretty sharp, he has some good ideas".
I hope you plan on fixing your rig. It's really to nice to just turn your back on it at this point.
[CENTER][B][SIZE="4"][URL="http://www.jeepforum.com/forum/f177/i-bought-my-first-jeep-week-its-xj-1392800/"]My '01 XJ 1 Ton Build Thread[/URL][/SIZE][/B][/CENTER]
[CENTER][URL="http://www.youtube.com/user/AKIQPilot"]My Youtube Channel[/URL][/CENTER]
AKIQPilot is offline   Reply With Quote Quick reply to this message
Unread 07-30-2013, 06:18 AM   #472
Kevin108
You guys are too kind! It will be fixed this time, for sure. The radiator will be here today so and I'll be working on straightening the crossmember and swapping the power steering pulley.
Unread 07-30-2013, 09:28 PM   #473
MattBillyTayloe
I've hit that too, but I didn't hit whatever you did up there thank god.
MattBillyTayloe is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 05:26 AM   #474
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
This right here is a reason to press on, you don't want Matt to have gone farther than you.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 07-31-2013, 12:30 PM   #475
MattBillyTayloe
This
Unread 07-31-2013, 05:27 PM   #476
Kevin108
I am such an introvert that I am absent the competitive drive most people have.
Unread 08-03-2013, 08:34 PM   #477
Kevin108
Tonight, on my build thread: Carol climbed a fence, Charlie bought a mug and I straightened my member.
Or something.
This is where we left off.
A trip to Lowe's yielded a solid 1/2" eye bolt and some fender washers. Other implements of destruction were also gathered.
I drilled a couple holes in the crossmember, installed the eye bolt with 6 washers behind the crossmember. I added a 3/4" shackle to the eye bolt and hooked a come-along between the shackle and a hook mounted in 1/2" plate on my truck's rear bumper. Wheels were chocked on each vehicle and careful pulls were made through both holes in the Jeep crossmember. A ball peen hammer was employed at times along with some 2x6, a Hi-Lift, etc. It's not aesthetically perfect but it's hidden behind the bumper, so I don't care. I'm sure it's not as strong as new but it's damn sure good enough for this Heep. I pulled measurements on the radiator posts and checked the clearances on each side and everything's going to work out fine.
Unread 08-30-2013, 02:08 PM   #478
Kevin108
I started planning my 14-bolt FF swap on my truck and decided I needed to finish the Jeep first so last night I ordered the last of the parts I need to put it back together. They'll be here probably the end of next week.
Unread 08-30-2013, 03:48 PM   #479
XJmike0122
Nice. Good to see another XJ getting back on the road.
XJmike0122 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2013, 11:26 AM   #480
Kevin108
This weekend I pulled the rest of the header panel, stuck the power steering pulley on, installed the AC condenser, radiator, electric fan, and fabricated mounting brackets so the trans cooler is attached independently. I've still go to install the header panel, serpentine belt, and fan shroud then pull the front bumper out of my garage attic, reinstall the LEDs, and modify the new grille for the lights. It's coming together though.
