Kevin108's 2000 XJ Build - Page 29 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Kevin108's 2000 XJ Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-30-2013, 05:08 PM   #421
Kevin108
Followed it up with a simple 2-bolt mount to the factory rack.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 09:26 PM   #422
Luke95
Looking good like normal man!
I <3 rockrash
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 04:50 PM   #423
Kevin108
Thanks Luke! Couple more pics.
Unread 07-01-2013, 08:05 PM   #424
Luke95
What do you have for tow points?
I <3 rockrash
Unread 07-01-2013, 11:29 PM   #425
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Can you post pictures of how you spliced your stock harness into your new lights?
Build Thread
April 2014 & 2015 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 11:48 PM   #426
Kevin108
I had OEM fogs and just cut the plugs off of them and flopped the wires inboard of the "frame rails." Pics and info from 2010 at http://www.jeepforum.com/forum/f177/...l#post10263358 when I did the first round of bumper-mounted Chinamart lights. It was just a simple strip/solder/heat shrink process each time. Even if you don't have factory fogs, the plugs are probably still there. If you have any other questions, please ask!
Unread 07-01-2013, 11:50 PM   #427
Kevin108
I <3 rockrash
2" Receiver w/ a HF shackle in the rear and C4x4 hooks up front.
Unread 07-02-2013, 01:28 PM   #428
MOBBiN
MOBBiN's Avatar
The big wires from the lights spliced into the smaller stock plug wires?
Build Thread
Unread 07-02-2013, 03:22 PM   #429
Kevin108
It's only like one size difference. This pic exaggerates that because my solder joint is on the fat side. But yeah, that's how I did it. Also, keep in mind that in this pic, I'm wiring it wrong. Chrysler switch the color pattern on the light side of the plug. It needs to be wired red to black and black to blue to maintain proper polarity. Incandescent bulbs don't care but the polarity has to be right for LEDs.
Unread 07-02-2013, 05:01 PM   #430
MOBBiN
MOBBiN's Avatar
Cool thanks for the info. Ill do the same for the squares
Build Thread
Unread 07-02-2013, 05:50 PM   #431
Kevin108
Glad I could help. Post pics!
Unread 07-02-2013, 08:44 PM   #432
Luke95
Were did you get the lights just wondering
I <3 rockrash
Unread 07-02-2013, 08:48 PM   #433
Kevin108
From my buddy Jay (Prime).
http://www.xterranation.org/showthre...-Flood-Squares
Take a look at his build thread if you visit their site. He has a badass 03 Xterra on 33s, rear ARB, rock rails, snorkel, etc. No flex shots though.
Unread 07-02-2013, 09:41 PM   #434
VegasGT
Rustler of Jimmies
VegasGT's Avatar
1988 MJ Comanche
PBR and Jeep work. A little piece of heaven indeed.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 11:27 PM   #435
Kevin108
When it's hot, you have to drink more, so I'm sticking with what's cheap. Sadly though, PBR has gotten so popular that it's within $1 per 24-pack of Miller Lite and Yuengling.
So much of our work has been under the partial possession of John Barleycorn, Prime and I started a wrenching-while-drinking feed on Facebook and Twitter.
http://www.facebook.com/DrunkMods
http://twitter.com/drunkmods
