Kevin108's 2000 XJ Build - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Kevin108's 2000 XJ Build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 11-03-2010, 09:07 PM   #151
Kevin108
Added pics of the head install. http://www.jeepforum.com/forum/f177/...l#post10387850
Also, I want to add that I got a lot of good info from the guys here. http://www.jeepforum.com/forum/f11/1...-what-1119119/ It made everything easier. Thanks again everybody!
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2010, 10:00 PM   #152
Kevin108
I pulled my rear bumper tonight to install my Grote grommet-mounted reverse lights. Got one cut in and broke the SawZall blade so I called it a night.
Unread 11-05-2010, 08:17 PM   #153
1jack5
For some reason that just makes me so mad when that happens to me... Post some pictures up when you are done.
1jack5 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2010, 08:43 PM   #154
Kevin108
I drilled holes for the wires in the bottom of the tail lights and then I realized the counter monkeys gave me the wrong pigtails so I couldn't wire anything up. I put the end caps back on because it will be next week before I can get the pigtails exchanged. I would have put the lights closer to the end caps but with my banged-up bumper, I had to move them inwards to get away from the dent and even further so as not to interfere with the mounting bracket. On second thought, being able to pop the light out of the grommet and reach straight in to undo the bolt would make pulling the rear bumper might easier. When I get a new bumper, I'll look into that arrangement.
With the hatch closed, the white license plate was freaking out the camera and everything else came out really dark so this is all I got tonight. I'll try to get some more pics tomorrow.
Unread 11-06-2010, 01:25 PM   #155
1jack5
I really like how that looks, Im gonna look into something like that for my TJ.
Unread 11-06-2010, 07:12 PM   #156
Kevin108
I think they look better the way Timstock did them but like I said, with my dent this was how it needed to be this time.
Unread 11-06-2010, 07:36 PM   #157
Kevin108
Today I made my first trip out to Shoe Creek with VBJO. I got 20 mpg on the way out now that everything's running right. It was 4-door day, apparently, as it was me and 3 JKs. The rest of the gang stayed and camped but to me it was too close to home not to sleep in my own bed tonight. It wasn't an overly-difficult trail but it was a great trail for beginners to hone their skills or for people getting back into it like me to put their rusty wheeling skills back in gear. With no armor, I didn't take the most difficult lines on anything but I was still very happy how my little stocker performed. So much so that I'm rethinking my plans on this build. Well, I'm going back to plan A, which was no lift, some armor and an extra set of tires. I think that's really all I'll ever need and the 31s I've drooled over the last few months would just be overkill.
This was the only decent pic I got today. Hopefully somebody else from the club got some.
Unread 11-06-2010, 10:45 PM   #158
zte87
GIVE IT THE ONION
zte87's Avatar
were did you get those clips to hold your maglight?
zte87 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 11:19 PM   #159
Kevin108
I bought them locally from a company called Tidewater Fleet.
Unread 11-09-2010, 11:29 PM   #160
Kevin108
Finally got some more pics from Shoe Creek.
Unread 11-18-2010, 08:59 PM   #161
Kevin108
My next two mods are going to be...more maintenance. I need u-joints for the front driveshaft and I need a new headliner as mine is sagging in two spots now.
Unread 12-02-2010, 01:05 AM   #162
1jack5
I like where you placed your extra back up lights better that the picture you posted of where you originally wanted them. It looks cleaner. What sliders do you plan to get?
Unread 12-02-2010, 09:39 PM   #163
Kevin108
I plan on going with the standard rock rails from AJ's Offroad Armor. AJ's Offroad Armor XJ Standard RockRails
Unread 12-02-2010, 09:47 PM   #164
Kevin108
More pics and info from my Grote reverse light installation:
The factory reverse light plug is clearly labeled GRD and MAJOR. Obviously, GRD is your hot wire. (Kidding!)
To make things easy for you: it's a black wire with a green stripe. On each side, I cut it, stripped it, twisted it, soldered it and heat shrunk it to run hot wires to the Grote lights.
For ground, I used the pigtail's round connector with a self-drilling wafer head screw into the body.
The test once everything was wired up.
What everything looked like in the dark.
Unread 12-03-2010, 12:55 AM   #165
MCObray
That's a pretty neat mod you did on the rear reverse lights. I still have yet to figure out all the wiring, just gives me one huge headache. Nice XJ
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline   Reply With Quote Quick reply to this message
