Kevin108's 2000 XJ Build - Page 34 - JeepForum.com
post #496 of 640 Old 10-09-2013, 07:20 AM Thread Starter
Kevin108
I did some thinking last night and I've drawn a line with how much more I'm willing to do with this. Parts replacement and mods are fine but tracking down electrical gremlins on an aging wiring harness that was sub-par even when new is a fool's errand.
If this next fix doesn't turn out simple, I'm going to start looking for a cheap 98-99 to start moving parts to. Failing that, I'm going to start parting it out.
This thing has been more work than fun the entire time I've owned it. I'm just done trying to fix the impossible and for the pittance it's worth, it's certainly not worth paying a pro to fix it for me.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #497 of 640 Old 10-17-2013, 02:00 PM
Luke95
97-99 are the tits years! I love my 98!
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #498 of 640 Old 10-21-2013, 10:40 AM Thread Starter
Kevin108
The 97s had sketchy wiring issues from being the first year of the update.
Kevin108 is offline
post #499 of 640 Old 10-21-2013, 09:26 PM Thread Starter
Kevin108
I bought some crappy saddle splices today and pulled the wire to temporarily reground the sensors. I located and spliced the pin 4 wire from the computer but then my wife had dinner ready and it got dark while we ate so I gave up for the night.
Kevin108 is offline
post #500 of 640 Old 10-22-2013, 05:01 AM
Luke95
98 2 door time.
I <3 rockrash
Luke95 is offline
post #501 of 640 Old 10-22-2013, 06:35 AM Thread Starter
Kevin108
Not a fan of 2-door anything.
Kevin108 is offline
post #502 of 640 Old 10-22-2013, 06:49 PM Thread Starter
Kevin108
Tonight I installed the temporary jumpers mentioned in http://www.jeepforum.com/forum/f177/...l#post16604449 I can now rev past 3,000 rpm but my idle is still **** and it sounds like it's missing. I'm going to look around and see if I have a spare camshaft position sensor. I'm going to go for a lengthy test drive tomorrow and see how it behaves as my current testing has been limited to a short stretch of yard in front of my garage. This is because the number of beers it took me to get motivated to work on this thing left me in no condition to operate it on public roads.
Kevin108 is offline
post #503 of 640 Old 10-22-2013, 06:58 PM
VegasGT
1988 MJ Comanche
Totally sig-worthy material there.
Ive had times like that as well, electrical woes are the worst. Cant resolve them with a hammer like most other Jeep issues.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #504 of 640 Old 10-23-2013, 06:11 PM
jordanread
I second that...
Kevin108, I remember that after you replaced your head, you mentioned that your camshaft got wobbly or something. I'm curious as to how you diagnosed it. I replaced my head (slowly, over the course of almost a year), but now I have a mysterious tick, and I'm hoping it's not what happened to you. I posted a video in my build thread, and was curious if you had any ideas...
To the destination, no matter where that happens to be, or what's in the way.
Boris
2000 XJ Sport - From stock to unstoppable.
(The fun)
(The write-ups)
jordanread is offline
post #505 of 640 Old 10-27-2013, 12:00 AM Thread Starter
Kevin108
Finally did my test drive. No change. Still need to swap the camshaft position sensor. Or just put it on Craigslist.
Jordan, no weird tick. Just the computer kept putting the engine in limp mode as it was shutting down misfiring cylinders.
Kevin108 is offline
post #506 of 640 Old 10-28-2013, 09:11 AM
jordanread
Gotcha. That makes me feel a bit better about my tick. Thanks!!
Boris
(The fun)
(The write-ups)
post #507 of 640 Old 12-01-2013, 10:26 PM Thread Starter
Kevin108
What's blue and stupid and still has issues but is running right again?
I can't explain why what was wrong with it occurred. The gap on the #2 spark plug had completely closed causing a constant misfire and requisite rough idle. The computer then went into limp mode, causing my rev issue.
Kevin108 is offline
post #508 of 640 Old 12-02-2013, 05:50 AM
Luke95
That sounds like a plug error! Not jeeps fault their!
Luke95 is offline
post #509 of 640 Old 12-02-2013, 06:57 PM Thread Starter
Kevin108
That plug has been in the head since I replaced it a whole other engine ago.
Kevin108 is offline
post #510 of 640 Old 12-02-2013, 07:48 PM
Luke95
I guess. It's a coil pack jeep though. I think that makes a diff
Luke95 is offline
My 2000 XJ Build jdhughes XJ/MJ Cherokee Non-Technical Forum 160 11-14-2013 07:11 PM
2000 hawaiian xj build redhanded XJ Cherokee Technical Forum 47 04-30-2011 08:15 AM
my 2000 XJ Build Thread! BlueXJ00 XJ Cherokee Technical Forum 8 07-26-2009 02:05 PM
2000 XJ build up NoSoupFoYou XJ Cherokee Technical Forum 79 07-08-2008 11:39 AM
