Just replaced rear door gas struts. To powerful! Slams door open. Is that normal? - JeepForum.com
post #1 of 41 Old 04-15-2013, 01:46 AM Thread Starter
Charley3
99 XJ
I bought replacement struts from Oreily Auto Parts for $20 each. Seemed like a great price since half what OEM or Crown cost off Internet.
However, these Oreilly struts slam the door open so hard it bounces up and down 3 times. They are to powerful and NOT progrssive rate.
Are OEM or Crown springs progressive rate? i.e. - do they slow down near end of travel? Is there a brand that makes progressive rate struts for rear door?
Do OEM or Crown struts slam door open?
I can still return the Oreilly struts.
What struts should I buy?
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #2 of 41 Old 04-15-2013, 02:50 AM
MrSundays
I got mine from the Zone and they are perfect... Except now my hatch sticks a bit closed and can be a bugger to open.
Sent from my pocket brick
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #3 of 41 Old 04-15-2013, 07:35 AM
mwitkowski24
I just bought some new ones from advanced yesterday and i was surprised at how stiff they were, and was wondering if they were too stiff. It says right on the package they are not designed to be compressed by hand.
So i guess its normal, its just a matter of whether you want your lift gate to hit you in the top of the head from falling or smack you in the face when opening.
mwitkowski24 is offline
post #4 of 41 Old 04-15-2013, 08:48 AM
Motorcharge
They loosen over time, but you need OEM spec if you have an older XJ because the fiberglass hatches wont handle it.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 41 Old 04-15-2013, 08:58 AM
ChEaPsK87
1987 XJ Cherokee
I got my struts from a ford explorer in the JY and I love the way they operate! not too stiff or loose
ChEaPsK87 is offline
post #6 of 41 Old 04-15-2013, 01:12 PM Thread Starter
Charley3
That doesn't sound perfect to me. Sounds like the opposite problem.
Charley3 is offline
post #7 of 41 Old 04-15-2013, 01:15 PM Thread Starter
Charley3
Years ago I replaced struts on my 96 XJ and they worked perfectly from the first day installed. I wish I could remember the brand.
Charley3 is offline
post #8 of 41 Old 04-15-2013, 01:19 PM Thread Starter
Charley3
I thought old XJ hatch was steel and newer XJ hatches were fiberglass. Do I have that correct or backwards?
Charley3 is offline
post #9 of 41 Old 04-15-2013, 01:28 PM Thread Starter
Charley3
Does any brand make progressive rate struts for rear door?
Charley3 is offline
post #10 of 41 Old 04-15-2013, 01:44 PM
BigBadWuf
1992 XJ Cherokee
That is backwards, old xjs have fiberglass hatch, newer ones are steel hatch. Like 98+? Are steel.
BigBadWuf is offline
post #11 of 41 Old 04-15-2013, 02:57 PM
Motorcharge
97+ are steel. Couldn't see his year on mobile, but the OP is fine. Old fiberglass ones will start to break in that area if they struts are too strong.
|SOLD|
| June 2015 COTM |
post #12 of 41 Old 04-15-2013, 04:13 PM
sAe23
1995 XJ Cherokee
X2
Ones I bought about 5 years ago started out forceful, then mellowed over time.
Now, if it's cold enough, they almost don't want to open on their own.
sAe23 is offline
post #13 of 41 Old 04-15-2013, 04:38 PM
buildin1XJ
I also have bought the ones from O'Rileys and they are strong at first but will loose some of that pressure over time.
buildin1XJ is offline
post #14 of 41 Old 04-15-2013, 05:07 PM
wassupjamesd
Had the same problem when I bought new ones from O'reily's, it was way too strong. So I changed 1 of them back to the old, weaker ones. So i have 1 old and 1 new one. Has been on for a few years, and works great still.
1999 Cherokee Sport 4x4, RE 3.5" SF, SYE, DS, and Monotubes, Pro Comp adj track bar. Soft 8s wrapped in 31x10.5x15 Dik Cepek Mud Countrys, Silverstars w/ HD harness, Class III rear hitch, Yakima snowboard racks, cool sunroof. NP231, C8.25, and D30.
wassupjamesd is offline
post #15 of 41 Old 04-15-2013, 06:07 PM
buildin1XJ
IMHO I would far rather have strong lift struts and it pop open than a weak system that will cause problems with the latch not disengaging and not letting it open. Many people also end up breaking the license plate light cover by shoving on it in an attempt to get the hatch open. But I will also say that most of the time when the rear latch does not disengage it is due to the latch arm needing adjustment.
