junkyard seats in an xj - JeepForum.com
post #1 of 17 Old 02-27-2013, 02:37 AM Thread Starter
tmarcum51
My 98 xj has a gangsta lean now. What junkyard seats can I use besides xj seats? I'll even take seats out of a rice rocket
If your having truck problems, I feel bad for you bud, I got 99 problems but my jeep ain't one.
tmarcum51 is offline
post #2 of 17 Old 02-27-2013, 06:01 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
ZJ seats.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 17 Old 02-27-2013, 07:49 AM
Motorcharge
ZJ and WJ front seats swap directly to 96+ bases. Much better seats too.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 17 Old 02-27-2013, 08:01 PM Thread Starter
tmarcum51
So wj seats will mount right up? Won't have to change brackets or anything? Do they sit higher or lower on the seat as well?
post #5 of 17 Old 02-27-2013, 08:04 PM
rugsucka
See post #3 - yes you need to switch the ZJ seats onto the XJ brackets
Then read a bit using the search tool for other details.
rugsucka is offline
post #6 of 17 Old 02-27-2013, 08:11 PM Thread Starter
tmarcum51
Alright.. does anyone know the average price of a seat from junk yards?
post #7 of 17 Old 02-27-2013, 08:17 PM
Motorcharge
Depends on the JY. The ones near me charge about $20 a seat.
|SOLD|
| June 2015 COTM |
post #8 of 17 Old 02-27-2013, 08:19 PM Thread Starter
tmarcum51
Alright. That sounds like a decent price.. wj seats are more comfortable then xj seats?
post #9 of 17 Old 02-27-2013, 10:19 PM
jeepkid03
Winning
jeepkid03's Avatar
Yes, and so are ZJ seats.
Keep in mind that Grand Cherokee seats at least in my experience sit about a half inch to an inch higher than XJ seats. This might be an issue for you if you have very little headroom with the current seats. I've swapped ZJ seats into my XJ and a buddy's XJ. Both are much comfier and the swap took 20 minutes.
The ZJ and WJ seats bolt directly onto 96+ seat tracks. Seats with manual recline require no modification. Power seats need wires run to them (a simple power and ground wire setup) in order to work.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #10 of 17 Old 02-27-2013, 11:07 PM Thread Starter
tmarcum51
I'm a shorter guy so headroom is not an issue haha. I just want a comfy seat.. I'm not worried about power seats either. What all do I need from the junk yard?
post #11 of 17 Old 02-28-2013, 05:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
2 seats from a ZJ.
post #12 of 17 Old 02-28-2013, 05:35 AM
jeepkid03
Winning
jeepkid03's Avatar
You just need the seats. There are bolts holding the seat to the seat tracks, just unbolt the seat from the tracks and bolt it on your XJ seat tracks.
-Josh
Build Thread:
post #13 of 17 Old 02-28-2013, 11:55 AM Thread Starter
tmarcum51
Alright. Thanks. I'll go to the junkyard this weekend
post #14 of 17 Old 02-28-2013, 11:59 AM
Motorcharge
Just to save you some time, it's 12 or 13mm nuts (forget which) that have to be removed. There's 4 of them, one in each corner of the seat. They're kind of a ***** to get to (front more so than the rear), but you can do it with a socket if you don't have ratcheting wrenches. It was a lot easier for me to get all 4 of them from behind the seats than trying to get to any of them from the front.
|SOLD|
| June 2015 COTM |
post #15 of 17 Old 03-04-2013, 02:11 AM Thread Starter
tmarcum51
Thanks for the help. I went with a set of wj seats out of a freedom edition one.. I couldn't be happier.. the nuts were a pain to get to. The seats I got had jeep embroidered right into the headrest and they look awesome.
