jeeppower window isssue - JeepForum.com
post #1 of 6 Old 06-08-2013, 09:08 PM Thread Starter
maloneyclan2
1998 FSJ Cherokee
Any info here will help. My driver side door control panel will operate all windows normally with the exception of the driver side window. Need some trouble shooting tips to determine if the problem is in the switch for the window or in the motor itself. Thanks folks.
maloneyclan2 is offline
post #2 of 6 Old 06-09-2013, 01:35 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wiring issues in the doors are very common. Inspect the wire harness looking for broken wires, chafed insulation, and failed wire splices. Look inside the rubber boot also. Once you are sure the wires are all good, consider that the master switch on the drivers door has failed.
CJ7-Tim is offline
post #3 of 6 Old 06-17-2013, 11:32 AM
JPCherokee
I have had this issue myself, for me it was the actual module with the switches on it. Replaced that, and all was fine
JPCherokee is offline
post #4 of 6 Old 06-19-2013, 07:23 AM
DNFJ
Me also.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #5 of 6 Old 06-19-2013, 07:38 AM
SuperSam
the switch internals are open to the environment, so the contacts can get corroded. If this is your case, get some emory cloth, nail file, etc. and clean them up, rebuilding any with solder as needed.
SuperSam is offline
post #6 of 6 Old 06-19-2013, 11:02 AM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I've had the same issue. I took mine apart and cleaned all the connections inside with a q-tip. Looked like the PO spilled a soda on it or something
April 2014 & 2015 COTM
MOBBiN is offline
