-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   jeeppower window isssue (http://www.jeepforum.com/forum/f177/jeeppower-window-isssue-1534038/)
maloneyclan2 06-08-2013 10:08 PM
Any info here will help. My driver side door control panel will operate all windows normally with the exception of the driver side window. Need some trouble shooting tips to determine if the problem is in the switch for the window or in the motor itself. Thanks folks. :confused:
CJ7-Tim 06-09-2013 02:35 PM
Wiring issues in the doors are very common. Inspect the wire harness looking for broken wires, chafed insulation, and failed wire splices. Look inside the rubber boot also. Once you are sure the wires are all good, consider that the master switch on the drivers door has failed.
JPCherokee 06-17-2013 12:32 PM
I have had this issue myself, for me it was the actual module with the switches on it. Replaced that, and all was fine
DNFJ 06-19-2013 08:23 AM
Me also.
SuperSam 06-19-2013 08:38 AM
the switch internals are open to the environment, so the contacts can get corroded. If this is your case, get some emory cloth, nail file, etc. and clean them up, rebuilding any with solder as needed.
MOBBiN 06-19-2013 12:02 PM
I've had the same issue. I took mine apart and cleaned all the connections inside with a q-tip. Looked like the PO spilled a soda on it or something
The time now is 01:40 PM.
