jeep 4banger good deal or not? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > jeep 4banger good deal or not?
Official Chassis Saver Rust Preventive Truck & Auto UnRough Country Lift Kits and Parts!1999-2004 Jeep Grand Cherokee Limited Headlight Pair
Unread 04-01-2014, 01:04 AM   #1
AM92
AM92's Avatar
1992 XJ Cherokee
allright jeepers.
I'm on the verge of buying a 1993 4banger 2wd 2door 5 speed with just under 165 k for pretty much under 1g i already own a 1992 with 6cyl 5 speed 4 door 4x4 wheeling only.
ive heard the 2.5l also known as the iron dukes are bullet proof motors or so ive heard
the real pros are low maintenance and some what decent mpgs
cons sucks on the high way and only good in town
The main purpose is to daily drive.
really what are ways to make the motor last awhile? I've heard people use lucas and swear by it
what axle may i have?
transmission?
4.10s only in the rear? dont know much about these models...
I also have ac factory option my other jeep was after market installed considering it came from arizona.
also am I getting a good deal?
AM92 is offline   Reply With Quote
Unread 04-01-2014, 04:42 AM   #2
mschi772
mschi772's Avatar
I'd happily daily drive a 5 speed 2.5 XJ. The 2.5 is basically the same engine as the 4.0 but with 2 fewer cylinders. Anything you've ever read about the 4.0 applies equally to the 2.5 in terms of maint./reliability.
If you want to know if it's a good deal, you should probably tell us the price.
2002-2009 1983 Chevy El Camino
2009-2011 1994 Cadillac Eldorado ETC
2011-Pres 1996 Jeep Cherokee Country
Wheels wanted to buy:
4 or 5 Turbines, old XJ 5-slot,
KJ 17x7.5 6-spoke, or KJ 16x7 5-spoke alloy
Paying ~$50 per wheel--Classified ad HERE
Have 4 (oxidized) Lace and 5 Eccos for potential trade
Biologist
Dog trainer
Mountain biker
Gamer
Jeep owner
mschi772 is offline   Reply With Quote
Unread 04-01-2014, 01:43 PM   #3
AM92
AM92's Avatar
1992 XJ Cherokee
I'm picking it up for 800
Unread 04-01-2014, 04:51 PM   #4
cbenez1
1991 XJ Cherokee
It's still 4wd and it's still a brick on wheels so if your buying it thinking your going to get great fuel mileage you'll be sadly disappointed. However if it is clean and stops & go's under it's own power I think it sounds like a good deal. It's a 2 dr 5spd, that alone ups the cool factor.
A nation that "forgets" it's defenders, Will itself be "forgotten". Semper fi
91 XJ 4.0 5spd 5.5 on 32's, flat flares, sand camo'd. "Battle Wagon"
01 XJ 'Up Country' 3.5 on 29's former fire vehicle. Bright red. "Fire Wagon"
cbenez1 is offline   Reply With Quote
Unread 04-01-2014, 06:05 PM   #5
mschi772
mschi772's Avatar
The one the OP is talking about isn't 4wd, and I've seen multiple 2wd 5-speed XJ's approach 30 mpg when cared for and driven appropriately with only a little modification. A 2.5 2wd XJ isn't much more than a glorified wagon, but I'd love to have one nonetheless; no preference on door number.
Biologist
Dog trainer
Mountain biker
Gamer
Jeep owner
Unread 04-02-2014, 12:45 AM   #6
AM92
AM92's Avatar
1992 XJ Cherokee
sweet! ill post pics when i get it!
Unread 04-03-2014, 02:29 PM   #7
cbenez1
1991 XJ Cherokee
Ok so it will be a 4cyl 2wd brick that doesn't get great fuel mileage and does not do well in poor driving conditions. But its still a cool truck.
Unread 04-03-2014, 09:23 PM   #8
cruiser54
cruiser54's Avatar
1990 MJ Comanche
And, it's not an Iron Duke. It's an AMC 2.46 litre four cylinder engine.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
Refresh*Connections*Before*Replacing*Components
cruiser54 is offline   Reply With Quote
Unread 04-03-2014, 09:41 PM   #9
Jake_A
$800? Hell, id buy it just for parts, considering crush value is about $450 for an xj, by me.
96 xj - bone stock, rebuilt engine & tranny, od-green/black, 256k
ISO Stock XJ tire carrier.
Jake_A is offline   Reply With Quote
Unread 04-03-2014, 10:00 PM   #10
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not to mention the possibility of low geared diffs.
Unread 04-04-2014, 07:16 AM   #11
Millermagic
Yup!
XJ was the first to use the AMC 150 I4.
I'd buy one. If I found a nice, stock 5 speed 2.5 XJ ... I'd probably make a trade. They aren't much for power, but are a great engine.
They crawl just as good as a 4.0.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline   Reply With Quote
Unread Yesterday, 02:23 PM   #12
AM92
AM92's Avatar
1992 XJ Cherokee
cherokee!
its been awhile but here it is! ive been daily driver her everyday only thing ive done was do the oil change and fix the broken door hinges other then that shes been good to me
Unread Yesterday, 04:45 PM   #13
mschi772
mschi772's Avatar
That is a spectacularly simple XJ: 2-door, 2wd, 5-speed, 2.5 4 cyl... I assume manual locks and windows as well. My lawn mower is a more complex machine than that (this is meant as a compliment by the way). White with black grill/flares and steelies is the cherry on top. I'd love to have that as a street/commute/dd vehicle--no higher than stock height, some narrow street tires, some thin metal or coroplast body skids to improve aerodynamics underneath, some subtle grill blocks for additional aero, and a S10 Blazer/Jimmy air dam added to the bottom of the stock air dam...with good maintenance and decent exhaust, we're talking easily 25+ mpg (I've seen a similar setup to the one I've described get 29 mpg, and it still looked like an XJ instead of some aeromodded freak Frankenstein car).
Biologist
Dog trainer
Mountain biker
Gamer
Jeep owner
