jeep 4.0 engine interchangeability - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > jeep 4.0 engine interchangeability
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome Open box items at OPENBOXOFFROAD.COMJeep parts, deals and more at JeepHut.com
Unread 08-06-2009, 08:29 PM   #1
01xjltd
I am in the process of getting a spare engine for my 2001 cherokee and i am curious which engines or combination of engine blocks will will work with my cylinder head
a. can i use a 97 to 99 block with an 01 head
b. can 97 - 99 complete eng work with 01 coil pack, ignition ,fuel system and computer
c. will an 01 head fit on a 96 and older short block
d. or am i limited to just 00 and 01 engines
e. can i convert the 01 engine set up to an older setup using a 99 or earlier engine.
I understand the 00 and 01 heads are unique to these 2 years and crack if they get hot so i want to get away from this if its at all possible. I also encountered alot of usable 4.0 longblocks in the yards i visited yesterday that are most likely going to scrap, and ide like to grab one or more if i can use em. Any usable help will be very much appreciated.
01xjltd is offline   Reply With Quote Quick reply to this message
Unread 08-06-2009, 09:24 PM   #2
jeep95xj
1995 XJ Cherokee
You can use any block you want. The 2001 head is not as good as the older head so personally if your engine goes, scrap it. Your intake manifold however is one of the best ones. Use the older block and head with your injection, intake manifold, and ignition system and you will be fine. You will also have to move brackets over but thats the easy part.
jeep95xj is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 11:24 AM   #3
01xjltd
Thanks a million for the reply. I crosschecked this with clifford performance and they validated your analysis. There is much interchangeability amoungst this engine family. Got some new project prospects as a result of this........ Outstanding
Unread 10-20-2009, 11:21 PM   #4
Sdenzik
1997 XJ Cherokee
Did this work will the 2000-01 ignition drop in to the earlier block and head? any problems with change over
Sdenzik is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 11:50 PM   #5
Luke94XJ
1994 XJ Cherokee
all you are changing is the electrical, with a coil pack change, I don't know why it wouldn't work.
Luke94XJ is offline   Reply With Quote Quick reply to this message
Unread 10-21-2009, 06:10 AM   #6
Greenmonster138
All the 4.0 blocks are pretty much the same.
Greenmonster138 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2009, 06:19 AM   #7
XJMuscle98
Rather than worrying about a problem that may not effect you at all, why not just improve your stock cooling system to ensure that it doesn't get hot?
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 04:00 PM   #8
anthonyduncan
will a 95 jeep 4.0 motor fit in a 96 grand Cherokee. and what about the transfer cases
anthonyduncan is offline   Reply With Quote Quick reply to this message
