JCR New Sliders - Page 3 - JeepForum.com
post #31 of 41 Old 01-24-2013, 01:43 PM
IDIdiesel
Originally Posted by brimy311 View Post
The calculation is, you won't be able to get the right torque on the bolt because the uniframe will be crushing.
We've been working on and playing with XJ's for 10 years. We have first hand experience with the uniframes crushing when bolted through without a sleeve.
The gains you think you are making by skipping "self tappers" is moot. The strength of the sliders comes from the winch seam mount.
If the strength comes from the pinch seam mount than mine would be stronger than the JCR mounts. The JCR only uses 5 bolts per side where mine have 7. Also my pinch weld is sandwiched between two peices of flat stock. As far as the unibody crushing without a sleeve, the backer plate is 4"x6" its not just a blot head and washer.
2015 Ford F350 crew cab, gasser
2001 Cherokee sport "AGENT ORANGE"
1991 Ford 7.3L IDI- FOR SALE
IDIdiesel is offline
post #32 of 41 Old 01-24-2013, 02:06 PM
ibjeepin95
Keep telling yourself that
lol x2
ibjeepin95 is offline
post #33 of 41 Old 01-24-2013, 04:46 PM
Project1
Hey JCR... I love your stuff... SO question ... whats the best way to run your ultimate sliders and a rough country long arm.... should I use a frame stiffener?
Project1 is offline
post #34 of 41 Old 01-24-2013, 08:14 PM
ibjeepin95
If you plan to wheel your XJ at all....yes.
post #35 of 41 Old 01-24-2013, 10:02 PM
Project1
So, what I really mean to say is ... Will the ultimate sliders work with say a rough stuff frame stiffener and the rough country long arm? Or will these things get in the way of the mounting of the slider?
Project1 is offline
post #36 of 41 Old 01-24-2013, 10:08 PM
ibjeepin95
Maybe if Rough Country made a frame stiffener. It all should work with frame stiffeners. Stiffeners add about an 1/8" of metal to your frame. It will be ok.
post #37 of 41 Old 01-24-2013, 11:05 PM
Project1
alright good to know .... Thanks brother
Project1 is offline
post #38 of 41 Old 01-24-2013, 11:20 PM
Jethro2797
1992 XJ Cherokee
Originally Posted by biggoofy
Lol your a special kind of stupid aren't ya. Eventually they will collapse the uniframe. I haven't done my Xj yet but I completely cut out the rockers on my Zj and replaced them with 2x4 and 2x2 directly welded into the a b and c pillars. I have yet to have a single issue.
If you know what you're doing, no need to crush the frame. Spread out the pressure, no problem
Jethro2797 is offline
post #39 of 41 Old 01-25-2013, 09:16 AM
brimy311
brimy311's Avatar
The long arm shouldn't be an issue. Our front legs are in a location to avoid interference with the Long Arm lower mounting brackets are crossmembers.
If you add or have frame stiffeners, there is a drop down box that says "Frame Stiffeners?" that you would check "yes" for. Then some extra spacers come with the sliders to make everything work together.
269.353.1184
for up to date product updates and specials!
Follow us on
brimy311 is offline
post #40 of 41 Old 01-25-2013, 10:22 AM
Metro55
Hey guy and JCR..
I have the JCR Stage 3 sliders and the RC Long Arms, I had to cut my front leg off the sliders and reweld it further towards the front of the Jeep to avoid the RC LA crossmember. FYI
EDIT: I don't have Ultimate Sliders, they appear that they would clear fine.
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #41 of 41 Old 01-25-2013, 10:35 AM
Frameless
Junior Member
They cleared my TNT lift. Highly recommend doing stiffeners before sliders.
Frameless is offline
