JCR Gas Tank Skid - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > JCR Gas Tank Skid
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 09-08-2011, 12:25 AM   #31
MCObray
Originally Posted by theducksguts View Post
I don't know, those plastic gas tanks look pretty attractive to all the rocks out there
Quick question... How much did the GTS sag your rear from the extra weight? I'm kind of worried that it'll droop my rear some with the added weight...
1999 Jeep Cherokee SE. Sold.
2000 Toyota 4Runner Highlander. E-Locker equipped.
MCObray is offline   Reply With Quote
Unread 09-08-2011, 11:23 AM   #32
theducksguts
None. I have no sag in my suspension. If your springs are in good order you should be fine.
00 XJ Sport 0331 Victim
99 XJ Sport
98 TJ
Check out my Classifieds
theducksguts is offline   Reply With Quote
Unread 09-08-2011, 11:42 AM   #33
MCObray
MM okay, just wondering. I have the OME Light Duty Leaf Pack, with the addition of 1 OME D22XL AALs in each pack.. I'm thinking I should be okay than...
Unread 09-08-2011, 03:58 PM   #34
theducksguts
Maybe, I put in full replacement lifted leaf packs, so I don't know. You could always do some 1" lift shackles to even it out if it was an issue.
99 XJ Sport
98 TJ
Unread 09-08-2011, 04:16 PM   #35
david92xj
1992 XJ Cherokee
that skid cant be more than 50 pounds. it wont be an issue imho
ive had a full size spare in my trunk for a few months now and theres no sag. and that is more like 70-80 pounds
david92xj is offline   Reply With Quote
Unread 09-08-2011, 05:23 PM   #36
MCObray
Same here. I'm thinking it won't be an issue, especially with the extra leaf I just added.
As in full size, what size? I have a 30x9.5x15 on the same aluminum wheel (Ravine) in the trunk.
Unread 09-09-2011, 12:36 PM   #37
MCObray
Okay so did a quick mock up with the JCR Gas Tank Skid plate:
With full tank of gas:
Front height: 19.75'
Rear height: 20.75'
With full tank of gas & JCR GTS in the rear cargo area:
Rear height: 20.00'
Hm....
Unread 09-10-2011, 12:41 PM   #38
Jeeper1973
i've got the JCR GTS on my 99 XJ, and let me tell you... that thing is flipping heavy! it's as solid as it could be... I wouldn't doubt that it could weigh down an XJ with older leafs, but a quick shackle lift would even it out if needed.
Everything JCR makes is heavy and solid... they have a nice transfer case skid plate as well.
Jeeper1973 is offline   Reply With Quote
Unread 09-10-2011, 12:47 PM   #39
david92xj
1992 XJ Cherokee
31x10.5x15 on a 15x8 steel wheel... soon to be mounted on my detours tailbone, whenever it shows up
Unread 09-11-2011, 07:10 AM   #40
theducksguts
someone really needs to do an aluminum skid package for the XJ. I would start selling off my steel right away.
99 XJ Sport
98 TJ
Unread 09-11-2011, 08:26 AM   #41
MCObray
someone really needs to do an aluminum skid package for the xj. I would start selling off my steel right away.
x2.
Unread 09-11-2011, 10:34 PM   #42
david92xj
1992 XJ Cherokee
There's a reason why they don't use aluminum. It dents very easily and will not hold up nearly as well as steel (getting hit with rocks wise)
Unread 09-11-2011, 10:39 PM   #43
MCObray
Really? It looks likes Savvy's gear for the TJ/LJs are pretty stout and there aluminum.
Unread 09-12-2011, 07:23 AM   #44
theducksguts
I beg to differ, let me run and go take some pictures...
Well it wasn't as visible as I though it was. What you can't see are gouges and scratches galore. It has held up to some serious rock abuse over the past 3 years. I come down on it hard many times on a trip because I currently lack the ground clearance. It does it's job well and couldn't be happier. I haven't asked but I wonder why Savvy hasn't come out with products for XJ's or even JK's yet. Maybe they are in the pipeline.
Here is the picture I promised of my JCR XJ skid. Notice the center bolt is not present because in my case it prevents the receiver hitch from use.
99 XJ Sport
98 TJ
