It's starting to rust :( - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > It's starting to rust :(
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 04-09-2011, 11:57 AM   #1
Millermagic
My oil treatment didn't work as planned ... my XJ is starting to rust. Hopefully I can get 3 or 4 more years out of it. I want to try to
save it , if I can.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline   Reply With Quote Quick reply to this message
Unread 04-09-2011, 12:23 PM   #2
blueridgexj98
1989 XJ Cherokee
Thats nothing you should have seen mine and many others, just clean it up, hit it with some rust preventative paint por 15, chasis saver, bedliner, or even some rustoleum, and be done with it (the rust)
blueridgexj98 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2011, 12:43 PM   #3
jeepkid03
Winning
jeepkid03's Avatar
x2 hit it with a wire wheel, then do some chassis saver.
-Josh
My 0331 Head Swap How-To Thread:
http://www.jeepforum.com/forum/f11/0...hread-1371398/
Build Thread:
http://www.jeepforum.com/forum/f22/m...build-1119997/
jeepkid03 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2011, 05:40 PM   #4
Green_MachineXJ
1995 XJ Cherokee
Thats literally nothing. When you have no floors like myself then you can complain.
Green_MachineXJ is offline   Reply With Quote Quick reply to this message
Unread 04-09-2011, 08:49 PM   #5
Millermagic
Either wire wheel or mini-sandblaster at Harbor Freight.
I still have floors and rocker panels
Unread 04-10-2011, 12:50 AM   #6
Dbiked
The second picture. . . What were you showing us that was rusted there? the leaves, and exauset just do that. they are things we replace. maybe im blind. But deffinatly dont worry about those, and you should search to see some of the rigs that have been saved from rust. Its truely magic what some of these guys have salvaged. Deffinatly something I plan on learning with my 65 Dodge Pickup!
Utah jeep crew member #32
Dbiked is offline   Reply With Quote Quick reply to this message
Unread 04-10-2011, 02:37 AM   #7
Hussler
1992 XJ Cherokee
I wish my Jeep was that clean
Working on this problem less than 20 miles away from you
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote Quick reply to this message
Unread 04-10-2011, 06:54 AM   #8
Millermagic
The second picture? There was a lot of brown in that picture. The exhaust on a 11 year old vehicle is going to rust off. I'm more worried about the piece of rust above the cat. Rusty leaves don't matter for me since they need to be replaced (drooping).
45 Miles. I moved out to Syracuse! I've seen some pretty bad Cherokees at Vinces. When I went to grab a tow hitch, I didn't even need to remove the bolts ... just pulled and the receiver and uniframe came with it.
Unread 04-10-2011, 07:21 AM   #9
Rockeasy
Rust?.... What RUST!?!?!?!
Rockeasy is offline   Reply With Quote Quick reply to this message
