IPF or Hella? - JeepForum.com
post #1 of 7 Old 07-26-2008, 05:34 PM Thread Starter
Wazzuppiggy156
1995 XJ Cherokee
IPF or Hella?
I recently came into a little bit of "mad" money by helping a co-worker clear some storm damaged trees from around his house. My question is simply which conversion kit produces MORE light output. The IPF conversion or the Hella 500(?). Assuming I go with IPF, are the H4 Fatboys worth the money?
Thanks in advance to all replies
HEY, want an XJ overhead console?
Wazzuppiggy156 is offline
post #2 of 7 Old 07-26-2008, 06:35 PM
CKUPQ
I can't speak on IPF, but I like my hellas. I'm assuming that you are speaking about 6054 H-4 conversion headlights.
Either our language or our culture needs to be expanded/improved so that there is a polite way to say:
Stop talking now, because I am going to stop listening.
99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear.
CKUPQ is offline
post #3 of 7 Old 07-26-2008, 06:39 PM
coors400
doesnt look very expensive at all
http://www.carparts.com/autoparts/It...D:100000275168
coors400 is offline
post #4 of 7 Old 07-26-2008, 09:24 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
You're talking about headlights, right? Hella 500s are aux lights. Anyway, IPF makes a better housing than Hella IMHO. Get the 80/140 watt bulbs and upgrade the headlight harness. Night will become as day.
Factory Four Link
XJLI is offline
post #5 of 7 Old 07-26-2008, 09:53 PM Thread Starter
Wazzuppiggy156
1995 XJ Cherokee
Yeah sorry I had just got home from work and was a little brain-dead
Is there really much of a difference in light output from the either two lights? I will be upgrading the stock harness to a relay system with 14 gauge wire.
Do you happen to have any pics of a before and after?
post #6 of 7 Old 07-27-2008, 01:30 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
I dont have any pics, but a friend of mine has Hella housings in his TJ (and had them in his XJ as well) and the beam wasnt as nice as a guy I wheeled with a few times who had the IPFs in his TJ.
Everything I hear on the interweb also says the IPFs are better. I (personally) dont know how I feel about upgrading the headlights that much ($$$), since I'd rather throw more lamps on to get an overall longer and wider beam, but a very good upgraded headlight system will work better than say, silverstar bulbs in stock housings and a pair of 55w Hella lamps.
That being said, my plan eventually is a pair of Hella E-Code H4s (not the normal Hella H4 conversion kit), a set of decent bulbs, and upgraded wires.
edit: As far as beam output, it doesnt matter what H4 kit you have. All the housing does is really give you a better beam. Actual light output will depend on the bulb (obviously) and more importantly, better wires. the stock ones are embarrassing. in fact, I have all this wire here and its raining out. I just might make a new harness.
Factory Four Link
XJLI is offline
post #7 of 7 Old 07-27-2008, 05:41 PM Thread Starter
Wazzuppiggy156
1995 XJ Cherokee
Thanks you for the good information!
All replies appreciated, I have decide to go with IPF housings and a set of their Magic J bulbs or the standards in the 100/170W. Edit: and the upgraded harness...
Thanks again for the help guys
Hella 500 VS Hella 500FF? Finallyajeep XJ/MJ Cherokee Non-Technical Forum 16 02-22-2010 11:27 AM
IPF vs. Hella BigwillXJ XJ Cherokee Technical Forum 12 04-10-2006 11:42 AM
Why I'll Never Buy Hella TPG013 XJ Cherokee Technical Forum 20 07-13-2005 01:29 AM
Hella 500 vs. IPF 968 01CherokeeSport XJ Cherokee Technical Forum 14 12-17-2004 02:06 AM
hella LOCKED UP XJ Cherokee Technical Forum 7 08-07-2002 11:39 AM
