Interchangable parts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Interchangable parts
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba~Artec JK 1 TON SWAP~
Unread 09-06-2014, 09:49 PM   #1
Slvr02Laredo
So Basically I just wanna know if the grille, headlight bezels and front clip from a 2001 xj will fit a 1992 xj
Slvr02Laredo is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 09:53 PM   #2
misfit77
I doubt it. Newer xj are rounded while old are squared. Maybe the front clip is interchangeable.
misfit77 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 07:39 AM   #3
Motorcharge
1992 XJ Cherokee
Yes, but it's not a direct bolt on and the body lines won't match. You'll get overlap with the fenders. The 97+ fenders will bolt right on to match the grill but the body lines won't match the doors.
|Project Motörcharge|
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 10:54 AM   #4
S8NNG8
1995 XJ Cherokee
Yes, but it's not a direct bolt on and the body lines won't match. You'll get overlap with the fenders. The 87+ fenders will bolt right on to match the grill but the body lines won't match the doors.
You meant '97+, right?
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2014, 05:23 PM   #5
Motorcharge
1992 XJ Cherokee
Yes.
Unread 09-08-2014, 11:10 AM   #6
Slvr02Laredo
Ok thanks for the input guys
