Indicator Panel Help - JeepForum.com
post #1 of 7 Old 03-19-2012, 11:01 AM Thread Starter
olblue87xj
olblue87xj's Avatar
1995 XJ Cherokee
The panel I'm referring to is the one to the left of the gauge cluster on '96 and older cherokees.
My 1995 cherokee recently failed va safety inspection because my airbag light didn't come on. I pulled the panel cover and it turns out I don't even have a spot on the panel for an airbag light. So now I'm thinking that maybe my cluster got switched out at some point?
Could someone please post up a picture of where the airbag spot is supposed to be on that panel?
Thanks!
1995 Cherokee
4.5 inch clayton/rustys lift|35 inch Goodyear Wrangler MTRs|LSD 8.8 rear axle with discs|Tom Woods cv rear driveshaft|Advance Adapters SYE|Clayton Offroad Long arms
Ol' Blue RIP
olblue87xj is offline
post #2 of 7 Old 03-19-2012, 02:05 PM
DriverX
I don't think pre '95s have airbags, which would indicate why you have no light. At least all teh pre '95s I looked at didn't have an airbag.
DriverX is offline
post #3 of 7 Old 03-19-2012, 03:20 PM Thread Starter
olblue87xj
olblue87xj's Avatar
1995 XJ Cherokee
Yea I think '94 and older cherokees didn't come with them either but this is for my '95.
I'm also wondering if it's legal in Virginia if I swap out my airbag steering wheel for a non airbag steering wheel. Anybody know?
1995 Cherokee
Ol' Blue RIP
post #4 of 7 Old 03-20-2012, 02:44 AM
DullesJeep
1995 XJ Cherokee
Pretty sure my 95 doesn't have an airbag light either...
This link: http://www.jeepforum.com/forum/f11/1...lights-639398/
Confirms that it doesn't exist.
As far as swapping your airbag wheel for non airbag per this link: (http://forum.miata.net/vb/archive/in.../t-238959.html) "Bottom line, if you have a car that came from the factory with air bags, VA state code requires they be in place...period. Mods made before the effective date of the rule (7/1/06)? Mods for your use only? Doesn't matter. You better get it back in the car, or take your chances with VA's finest. If your inspection station lets you get away with it, they have violated the code."
And straight from the horses mouth: (http://www.vsp.state.va.us/Safety.shtm) "20. – INSPECT AIR BAG AND AIRBAG READINESS LIGHT FOR:
Any defects in the air bag system noted by the air bag readiness light, or otherwise indicated; or
The air bag has been deployed and has not been replaced (and is not deactivated because of a medical or other exemption and a notice is posted to indicate that it has been deactivated); or
Any part of the air bag system has been removed from the vehicle; or
If the air bag indicator fails to light, or stays on continuously."
Doesn't say anything on there about the light simply not being there. I don't see how or why they can fail you for inspection on something that's not there to check in the first place.
It's a Jeep thing. Sometimes I don't even understand.
DullesJeep is offline
post #5 of 7 Old 03-20-2012, 07:14 AM Thread Starter
olblue87xj
olblue87xj's Avatar
1995 XJ Cherokee
DullesJeep thank you for your response! I'll just have to go to another inspection station and if they give me a hard time I'll be able to tell them why there's no light.
1995 Cherokee
Ol' Blue RIP
post #6 of 7 Old 03-20-2012, 08:37 AM
DriverX
You can also get your build sheet for proof. Mine clearly states CGTS Driver Air Bag Only.
Good luck with this!
DriverX is offline
post #7 of 7 Old 03-20-2012, 09:32 AM Thread Starter
olblue87xj
olblue87xj's Avatar
1995 XJ Cherokee
Thanks DriverX! Just sent out a request to Jeep for my build sheet so I can go ahead and bring that in when I get it reinspected.
1995 Cherokee
Ol' Blue RIP
indicator , light , panel
Oil Indicator light is on ridingsupreme XJ Cherokee Technical Forum 1 04-21-2009 12:59 PM
Gear Indicator nascartony05 XJ Cherokee Technical Forum 0 02-12-2008 08:45 AM
4wd Indicator Light out on IP Brighton Jeeper XJ Cherokee Technical Forum 7 02-14-2005 07:34 PM
