im confused about a lift - JeepForum.com
post #1 of 17 Old 04-26-2012, 11:20 AM Thread Starter
97cherokee1997
Ok so i already have my 2 inch coil spacers for the front but the back i have no idea every body is telling me somthing different so for the back should i get a 2 inch shackle and hanger lift or a 2 inch block or a add a leaf 2 inch i have no idea what to get for the back i need so help by the way its a 97 jeep cherokee sport
97cherokee1997 is offline
post #2 of 17 Old 04-26-2012, 11:38 AM
Corcor4
1990 XJ Cherokee
Stay away from blocks and add a Leif's usually sag eventually. Get the shackles
My second try: 1990 Jeep Cherokee Xj 6.5ish" lift with tj componets, 33" duratrac's, oversized roof rack, onboard air, body armor.
-OREGON JEEP OWNERS, NORTH WEST CREEPING JEEPERS
18 years old and lots to learn :D
Corcor4 is offline
post #3 of 17 Old 04-26-2012, 11:41 AM Thread Starter
97cherokee1997
post #4 of 17 Old 04-26-2012, 11:44 AM Thread Starter
97cherokee1997
And 1 more ? If i do 2 inch front coil spacers and do 2 inch rear shackles and dont replace the shocks will it death wobble and or will it still be a good comfertable ride?
post #5 of 17 Old 04-26-2012, 11:45 AM Thread Starter
97cherokee1997
post #6 of 17 Old 04-26-2012, 12:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Read this thread ->> Spacers vs. Shackles vs. Add-a-Leaf vs. full Leaf Spring pack
CJ7-Tim is offline
post #7 of 17 Old 04-26-2012, 12:50 PM Thread Starter
97cherokee1997
If i do a shackle and hanger rear lift kit should i get a longer shackle or a longer hanger????
post #8 of 17 Old 04-26-2012, 01:05 PM
NJXJ91
Yo man, my best advice would be to search. This stuff has been covered a bunch of times.
Since you already have the coil spacers, I'd get the 2.5 AAL or Old Man Emu leaf packs (medium duty.) I think you should get the full leaf packs. If I were you I would completely forget the though of shackles or blocks.
NJXJ91 is offline
post #9 of 17 Old 04-27-2012, 11:17 AM
Corcor4
1990 XJ Cherokee
Or go to napa/autozone and shackles that's are for lowering Chevys (forgot the year) actually raises jeep 2 inches and there like 25/ea
Corcor4 is offline
post #10 of 17 Old 04-27-2012, 11:22 AM Thread Starter
97cherokee1997
Ok let me ask this do you think these will get me a 2 to 3 inch lift. their air shocks for the rear http://m.advanceautoparts.com/mt/sho...RPSHOCAMS_____
post #11 of 17 Old 04-27-2012, 05:31 PM
billabongopblue
You should get new leaves.
Next best is to get a AAL - some will disagree. They will not last more then 3~ years. Although with the quality of the XJ stock leaves the shackles will make them sag and wear worse then they already are.
Lastly, would be to get shakles. You should get som that are adjustable in case you get new leaves in the future (likely) because of the further sag you will get.
Dont get blocks. They do not work on XJ's. forget what people tell you, they probably put them on their 80's pickups.
Furthermore,
with 2" lift you need nothing changed. If you want to get new shocks, then the JK stock shocks will work great all around up to 3".
3" lift you will need a track bar and rear brakeline etc.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #12 of 17 Old 04-27-2012, 07:00 PM Thread Starter
97cherokee1997
Thanks man just one ? What about air shocks. Would these if i were to get these. http://m.advanceautoparts.com/mt/sho...RPSHOCAMS_____
post #13 of 17 Old 04-27-2012, 07:12 PM
rugsucka
Did you bother to read the link in post #6??? You are not listening to the advice from people who have lifted and wheeled their rigs for years.
Air shocks are for hauling and street queens, not jeeps. They are not for lifts, springs are.
You can use shackles and risk fatiguing worn leaf packs, AAL and risk sagging in a year, Bastard packs and do a bit better than most AAL, or buy a proper lifting full leaf pack. You have choices, air shocks and lift block spacers are not them.
rugsucka is offline
post #14 of 17 Old 04-27-2012, 07:14 PM Thread Starter
97cherokee1997
Sorry bro im just doing this all off my phone and the links dont pop up for me for some reason my bad
post #15 of 17 Old 04-27-2012, 07:16 PM Thread Starter
97cherokee1997
And my friend some how rigged his so he could pump up his air shocks and almost give him 5 inches of lift its sweet
