I'm baaaccckkkkk!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > I'm baaaccckkkkk!!!!
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-24-2015, 09:13 PM   #1
USAFRecon
Xj I'm baaaccckkkkk!!!!
USAFRecon is back!! I finally got back in the seat of a Jeep. This time a 2000 Cherokee Sport. Already has a 3' Skyjacker and 31s.
Plans?
Of course there are plans. Bumpers front and rear, fender flares, 33s, slider/steps, some better lighting which I will need to do more research on, and a basket on the roof.
Sorry for the potato pics, it is dark and that is when the iPhone fails, taking dark photos in a bright garage...
USAFRecon is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 09:27 PM   #2
USAFRecon
My build sheet I got it from: http://www.farkistan.org/votsws.php
VIN 1J4FF48S2YL137290
Vehicle Description 2000 JEEP CHEROKEE SPORT 4X4 SPORT UTILITY 4-DR
Monotone Paint
124 Amp Alternator
500 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Highline Door Trim Panel
Reclining Front Seats
Rear Fold w/Removable Cushion Seat
Traveling Inboard Seat Belt Buckle
Next Generation Front Air Bags**
Carpets - Floor and Cargo Area
Cargo Compartment Carpet
Cargo Tie Down Loops
Plastic Liftgate Trim Panel
Spare Tire Cover
Passenger Assist Handles
Lift Gate Assist Handle
Full Length Floor Console
4-Speed Automatic AW4 Transmission
Command-Trac Part Time 4WD System
Dana 30/181MM Front Axle
Corporate 8.25 Rear Axle
Tinted Windshield Glass
Front Door Tinted Glass
Rear Window Defroster
STANDARD EQUIPMENT
Rear View Day/Night Mirror
Deluxe Insulation Group
Instrument Cluster w/Tach
Instrument Panel Black Bezel
100 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
RADIANT SILVER MET. C/C - BADGE - CH
RADIANT SILVER MET. C/C - BADGE - JE
RADIANT SILVER MET. C/C - BADGE - 4
RADIANT SILVER MET. C/C - JEEP
RADIANT SILVER MET. C/C - BADGE - SP
BLACK - MOLDING - BODYSIDE
EXTERIOR COMPONENT COLOR
Headlamps On Warning Chimes
Halogen Headlamps
CHMSL Lamp
Black Front Bumper End Caps
Body Color Front Bumper
Black Rear Bumper End Caps
Body Color Rear Bumper
Front Bumper Guards
Body Color Headlamp Bezels
Body Color Grille
Black Windshield Moldings
Rear Qtr Solid Window Insert
Belt Moldings
Body Color Drip Trough Molding
Black Door Handles
Body Color License Plate Brow
EVAP Control System
20 Gallon Fuel Tank
Forest Green Pearl Coat
AM/FM Cassette Radio
Fixed Long Mast Antenna
Power Steering
Normal Duty Suspension
Front Stabilizer Bar
Rear Stabilizer Bar
Compact Spare Tire
Inside Mounted Spare Tire
P225/75R15 Wrangler RT/S AT Tires
15X7.0 Full-Face Steel Wheels
Upgraded OBD-II Connectors
Tethered Fuel Filler Cap
Protective Coating and Remover
Build To U.S. Mkt. Specifications
GVW Rating - 4900#
U.S. Dealer Retail
Zone 35-Washington
U.S. Specifications Label
Maryland Ship to State Code
Maryland Sold to State Code
Prem Cloth Hi-Back Bucket Seats
Agate
OPTIONAL EQUIPMENT
Sport Value Group
Light Group
Power Equipment Group
4.0L Engine(ERH)/4Sp Auto Trans(DGS
High Back Bucket Seats
Front & Rear Floor Mats
All 4-Speed Automatic Transmissions
Lock-Up Torque Converter
Floor Mount Automatic Shift Lever
3.55 Rear Axle Ratio
All Engines
4.0L I6 Power Tech Engine
Deep Tint Sunscreen Glass
Deep Tint Sunscreen Liftgate Glass
Sun Visors w/Illum Vanity Mirrors
Power Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
Rear Window Wiper/Washer
Power Windows
Power Locks
RADIANT SILVER MET. C/C - 4.0L
Courtesy Lamps
Map/Dome Reading Lamps
Underhood Lamp
Cargo Compartment Lamp
Headlamp Off Time Delay
Front License Plate Bracket
Roof Rack
California Emissions
Northeastern States Tracking
Low Emission Vehicle (LEV)
All Radio Equipped Vehicles
4 Speakers
Leather Wrapped Steering Wheel
Tilt Steering Column
Goodyear Brand Tires
All Steel Wheels
8 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TJ
Customer Preferred Package 26J
Sport Appearance Group Discount
Customer Preferred Discount
Unread 07-25-2015, 07:59 PM   #3
USAFRecon
Can you guys give me some headliner ideas? I am headed to a junkyard tomorrow and will be attempting to source a headliner board since then en hasn't got one. I am thinking of getting fabric from Hobby Lobby or the such, maybe a camo pattern? Any ideas are much appreciated!
Also might be trading a guy my 31s for 33s on stock steelies.
Unread 07-25-2015, 08:29 PM   #4
FairlanePhil
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is online now   Reply With Quote Quick reply to this message
Unread 07-26-2015, 06:39 AM   #5
cbenez1
1991 XJ Cherokee
Nice Phil...
A nation that "forgets" it's defenders, Will itself be "forgotten". Semper fi
91 XJ 4.0 5spd 5.5 on 32's, flat flares, sand camo'd. "Battle Wagon"
01 XJ 'Up Country' 3.5 on 29's former fire vehicle. Bright red. "Fire Wagon"
cbenez1 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 07:22 AM   #6
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Phil was that an excellent post.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
