ibjeepin95's 99' XJ Build - Page 97 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 06-04-2013, 05:00 PM   #1441
Luke95
Originally Posted by ibjeepin95
You're just jealous because your taller XJ wouldn't stay with mine .!..!.
Not gonna lie I'm digging this whole 3.5 33s
I want 35s or bigger next
Sent from go home iPhone your drunk.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 06-04-2013, 06:24 PM   #1442
DNFJ
DNFJ's Avatar
37s on 6.5 lmk
Just Another Yellow TJ
Built Not Bought #704
Previous:
'00 XJ 6.5 on 35" KM2s
'96 ZJ 2 on 31" Baja Claws
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 08:13 PM   #1443
Luke95
Originally Posted by DNFJ
37s on 6.5 lmk
No balls
Unread 06-04-2013, 08:55 PM   #1444
CTeunuch
NACfest is two weeks away, you still thinking of coming up?
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:38 AM   #1445
ibjeepin95
ibjeepin95's Avatar
Originally Posted by DNFJ View Post
37s on 6.5 lmk
And an exploded Dana 30...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:41 AM   #1446
ibjeepin95
ibjeepin95's Avatar
Man, there is no way I can. I'm working 60-70 hours a week, money is good, and unfortunately I still got a few small odd and end things I need to figure out before I drive that far. I'm going to work on some of those things this weekend. However, I think I may shoot for the October event you guys have.
Unread 06-05-2013, 07:10 AM   #1447
DNFJ
DNFJ's Avatar
An unlocked, built HP30 should be able to handle 37s, the minute you lock it however.
So any suggestions from you on cutting my output shaft to do my SYE? I haven't done it yet because it makes me nervous.
Previous:
Unread 06-05-2013, 07:39 AM   #1448
Luke95
My gear guy said it was the 4.88 that killed his he was on 4.10s for a year no problems with an ax15.
4.56 are tougher than the 4.88s he said he run them if he wasn't on tons...
Unread 06-05-2013, 07:57 AM   #1449
DNFJ
DNFJ's Avatar
I'm probably going to go HP30, C8.25 built up with 4.56s anyways.
Previous:
Unread 06-05-2013, 10:02 AM   #1450
VegasGT
VegasGT's Avatar
Good combo. Ive been real content with the hp30/8.25 combo strength wise. I was coming up a rock ledge under throttle on the last WBR trip and ended up bouncing around on everything pretty violently with no parts shed. Once I get all the other conponents beefed up I have no fear of the axles holding 35s. ibjeepin has been good proof of that as well lol.
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is online now   Reply With Quote Quick reply to this message
Unread 06-05-2013, 10:30 AM   #1451
alexrule123
The spider gears like to let go even with 35s and when that happens you have to rebuild the whole axle.
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 10:41 AM   #1452
DNFJ
DNFJ's Avatar
And you and ibjeepin also beat on your rigs much harder than I do.
crawlers.
Previous:
Unread 06-05-2013, 11:01 AM   #1453
ibjeepin95
ibjeepin95's Avatar
You'll be ok mall crawlin' .!..!.
I'm surprised my ***** has held up like it has. I know when to let off, but sometimes I don't. So far, I've only broke one shaft. And I do beat on it a little...
Lunch box locker or full case locker. Done.
crawlers.
I do, and it may be considered "crawling", but you wouldn't consider it slow if you rode with me once
Unread 06-05-2013, 11:08 AM   #1454
DNFJ
DNFJ's Avatar
If I had more money I would be all about doing jeepspeed.
Crawling even when it's quicker paced stuff just doesn't really interest me.
What I really want is a pre-runner MJ and an expedition XJ (which mine is slowly turning into).
Previous:
Unread 06-05-2013, 11:10 AM   #1455
ibjeepin95
ibjeepin95's Avatar
ANYWAYS, I got some plans for my XJ. First, let me say, it wheels fawking awesome. I'm 100% happy with that. However, I got some issues I want to fix to make it moe streetable and to gain some power back. So, here are the future plans as of now:
-Do an alignment and get the steering wheel straight
-fix nutsert at cross member
-install my ZJ seats
-patch all the ****ing holes in the floor I had to cut out for the 3 link (long story)
-Herculine the floor?
-cut a section out of my crossmember to lower the drivetrain some
-possibly redo the rear leaf setup
-valve cover gasket
-4.88's
And maybe, next summer it will get a a cage...
