ibjeepin95's 99' XJ Build - Page 87 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 05-02-2013, 05:33 PM   #1291
ibjeepin95
Originally Posted by SFRautomotive
from what ive seen, all the RK stuff is good quality and pretty badass.
That's what I've seen.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 05:34 PM   #1292
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
i havnt personally messed with any of there XJ stuff. but the TJ and JK systems ive installed have been pretty beefy
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 07:15 PM   #1293
ibjeepin95
Yeah. Their joints aren't too bad either from what I hear.
Unread 05-03-2013, 08:17 AM   #1294
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Welp, no turning back now. Just ordered the RK 3 link!
Should have saved and just when full coils.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 08:39 AM   #1295
ibjeepin95
Full coils? Coil overs?
Unread 05-03-2013, 09:00 AM   #1296
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
RK has a 4.5" and 6.5" lift that is rear coil conversion.
If you wanted to spend extra money and get coil overs that would be your choice.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 05-03-2013, 10:08 AM   #1297
ibjeepin95
Eh, I like my leafs. They keep the Jeep stable and are stupid easy to work with. If I was to do a coil conversion, I wouldn't buy a kit. I've haven't heard good things about "kits" for a conversion. If I was to do it, I'd build it like SFR did.
Unread 05-03-2013, 10:12 AM   #1298
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
I wouldn't even convert to coils, if I was gonna do it I'd comp cut then get coil overs. Better return for the money/time spent imo.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 05-03-2013, 11:11 AM   #1299
ibjeepin95
I wouldn't comp cut unless I'd stretch. As far as stretching goes, it's seriously worthless unless you are on 40's or over. A 102" wb is damn near perfect for most situations. On 35's and anything over 102", I'd feel like I was wheeling a school bus. As far as coil overs go, I wouldn't even begin to waste the time or money on junk stock axles for coil overs. I feel like once I get this 3 link in, a little more adjustment to the leafs, a set of prothanes, and maybe some limiting straps and I'll be good.
Unread 05-03-2013, 11:18 AM   #1300
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Oh I'm with you on that, and that is the direction my build will take as well, but if money was cheap, coil overs, 37s, comp cut, and a 2-3" stretch would be what I wanted.
And yes upgrading to "real" axles would be part of that process as well. Can't wait to see RKs 3-link set up on your XJ.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 05-03-2013, 11:22 AM   #1301
ibjeepin95
I can't either. Hopefully it will get here sooner than later!
Unread 05-03-2013, 01:34 PM   #1302
Weeder1
What prothanes are you looking at? I want to do something diff with my front bumps, they have no give and hit hard. Lol
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 02:43 PM   #1303
ibjeepin95
The ones from summit or jegs. Probably ones that fill the whole coil.
Unread 05-03-2013, 04:29 PM   #1304
Weeder1
I wish i could find a soft bumpstop that doesn't look ugly as **** like those. Thought about fox air bumps...
-98 xj sport-
Unread 05-03-2013, 05:49 PM   #1305
ibjeepin95
Haha, ate you planning on going fast or something? Lol
