ibjeepin95's 99' XJ Build - Page 70 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 03-25-2013, 02:27 PM   #1036
Luke95
I got a ***** pile of 2x3 1/4" steel, so I'll just add onto it with that. My bumper is flat with the grille, but I will make the wings stick out a little to fend off trees and rocks.
That what I was thinking. So on that note I am tired of this lcog fad. 3 inchs lift and 33s is small not LCOG. Vent off.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 02:29 PM   #1037
ibjeepin95
ibjeepin95's Avatar
Originally Posted by koolaid5 View Post
Did he have a collar and tags, so that you could at least let the owner know? I would have been sobbing like a little ***** and it would be very painful to contact the owners, but I couldn't live with myself if I didn't. My 3 dogs are part of the family. It's like I have 5 kids instead of just the two.
Nope. I have 2 dogs myself. It sucks, but like I said, it happens all the time around the same spot. It's unfortunate, but there are so many houses through there that it's impossible to find who the dog belongs to.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 02:31 PM   #1038
ibjeepin95
ibjeepin95's Avatar
I don't look at it like a "fad". I do it because it works. Like I've said, it takes just as much work if not more to make a low XJ work then to make a tall lifted XJ work.
Unread 03-25-2013, 03:50 PM   #1039
Luke95
On my new one I have a simple plan. And I'm going to keep it that way. Not to be low but be stable and well built.
Sent from under my broken Heep
Unread 03-25-2013, 04:52 PM   #1040
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
So much truth.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 05:21 PM   #1041
aircruiser
So basically, youre new one will have a Low Center Of Gravity..
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 05:28 PM   #1042
Luke95
yes. But thats not the direct point of the build, more like something I can wheel, DD, and not have to worry to much.
small built jeeps can be cooler than unbuilt big jeeps
Unread 03-25-2013, 05:29 PM   #1043
MattBillyTayloe
He acts like its a bandwagon lol. I prefer the look of low and beefy than tall, and I hear the problems people have after going 4.5" and up, lol, no thanks. I'll stay "small" as he puts it
MattBillyTayloe is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 05:44 PM   #1044
1990JEEPXJ
1990 XJ Cherokee
What problems do you speak of? I'm at 6" and no problems. And have a good balance of up travel and droop and belly clearance
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 03-25-2013, 05:54 PM   #1045
ibjeepin95
ibjeepin95's Avatar
I would imagine he means drive line / suspension geometry. Even if you stay low,you should still correct these issues. I didn't need an SYE because of my suspension height, but because of my transfer case being pushed up because of my cross member and causing drive line issues. As far as suspension, yes, short arms have a better geometry at lower heights.
Unread 03-25-2013, 06:00 PM   #1046
MattBillyTayloe
I can't name something off the top of my head, I'm jut going off of what other people have said. I think they were referring to stuff they had to replace upgrade be auss of going higher, as well as what ibjeepin was dating about driveline and steering geometry
Unread 03-26-2013, 04:05 PM   #1047
ahar9
Steering, drivelines, brake lines, control arm angles, higher center of gravity so less stable, that kinda ****. I think low is the way to go although it's not because you don't have to deal with some of those problems. You actually end up paying more building a lower rig.
if nothings breaking your not wheeling it hard enough
ahar9 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 05:41 PM   #1048
ibjeepin95
ibjeepin95's Avatar
X2. I've also done much more fab work to make low work than I would've had to do to make a tall rig work.
Unread 03-26-2013, 05:44 PM   #1049
MattBillyTayloe
Speaking of fab, did you make your own sliders, of so, any idea where that page is ? trying to get some together soon, less scrape and bend more slide.
Unread 03-26-2013, 06:07 PM   #1050
ibjeepin95
ibjeepin95's Avatar
Page 14 broski
http://www.jeepforum.com/forum/f177/...2/index14.html
