ibjeepin95's 99' XJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-15-2012, 07:38 AM   #91
ibjeepin95
Originally Posted by DezertXj88 View Post
My concerns go to the axle. Outer C's, upper control arm mount and possibly sleeving it to help hold the 35's.
I've wheeled stock 30's on 35's a good bit. The main concern is the shafts and ring and pinion.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2012, 04:07 PM   #92
DezertXj88
1990 XJ Cherokee
Well I could get used to the low gearing...or are you talking strength wise?
I have a 5speed and 3.55's, 3.55's & 35's will be almost identical to 31's & 3.07's. Which isn't to bad..but I would regear once the rest of my rig is done.
Strength wise may become a problem...its more of a camping/ExPo rig, but I do some mild/moderate trails. Shafts just got spicer 760X's but I've been looking for chromos..I'm truely thinking about running 35's lol.
My D30 is sleeve, boxed upper CA mount, CA mini skids & gusseted outer sleeves.
DezertXj88 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2012, 04:40 PM   #93
ibjeepin95
I was talking strength wise.
Unread 04-15-2012, 04:51 PM   #94
ibjeepin95
So I got the diybeadlocks.com bumpstop plates installed....
And I went ahead and made some braces since I thought they would bend....
Unread 04-22-2012, 07:19 PM   #95
jeepnatv4life
Crozet Wheelin
moveable rox suck!!!!
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 07:21 PM   #96
jeepnatv4life
for all the haters.....low and 35's flat worx!!!
'13 RZR 570
Unread 04-22-2012, 07:41 PM   #97
ibjeepin95
I'm totally happy with this setup. Works awesome, no rubbing. I do, however, need to put another washer behind the steering stops. I got a little lca lovin' from the tires. Also, I NEED TO GET SOME SHOCKS IN THE BACK!!!!! Crozet also did some bodywork. I'll get more pics of that later, but I need to do some rocker replacement.
Unread 04-23-2012, 10:05 AM   #98
Clayton
At least your out wheelin . Looks good
Clayton is offline   Reply With Quote Quick reply to this message
Unread 04-23-2012, 11:16 AM   #99
ibjeepin95
Yup! I got to get used to this Jeep. Been a while since I have wheeled an XJ!
Unread 04-24-2012, 06:30 PM   #100
ibjeepin95
More pix...
Unread 05-01-2012, 03:50 PM   #101
ibjeepin95
Today I FINALLY ordered a set of Trail Gear shock hoops from Foothill Motorsports off of Pirate. Got them for a great price. They will match any TG price you can find.
Unread 05-02-2012, 09:23 PM   #102
Hussler
1992 XJ Cherokee
And we will be painently waiting for results
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote Quick reply to this message
Unread 05-03-2012, 05:26 AM   #103
ibjeepin95
Haha, I'm a little nervous because the only info I can get are pretty much just from pics. BUT I'm also not too worried about how $h!tty my cuts look because this isn't a DD. So I'll get a set of hoops in there some how .
Unread 05-03-2012, 10:00 AM   #104
jeepnatv4life
Bring it to the Robdizzle's i should have or can get the tooling to do it nice..
'13 RZR 570
Unread 05-03-2012, 05:14 PM   #105
ibjeepin95
OOOORR you can roll up to my casa the weekend I do it!!
