ibjeepin95's 99' XJ Build - Page 52 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Unread 02-18-2013, 09:58 PM   #766
CTeunuch
Originally Posted by 1990JEEPXJ View Post
Like I'm sure you've read, just do small 2" or so stitches at a time and let cool a bit before moving on. When welding to the cast center, use a torch to heat it a bit then weld then hit it with the heat again a few times a minute for a couple minutes. I had a few crack before I did that and that fixed it. The tubes are nothing special. Just don't focus on one spot too much to prevent warping.
Good advice. The only thing I would add is to peen the weld, either with a ballpeen hammer, or a needle scaler after you do each pass, and to wrap the pumpkin/tubes in an old blanket or two when you're done to let it cool slowly.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:39 PM   #767
ibjeepin95
Got a good deal on some good **** today...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:59 PM   #768
Weeder1
Gay, send them down to fl.
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 08:37 PM   #769
ibjeepin95
Which part? lol
Unread 02-19-2013, 08:46 PM   #770
crockett07
1992 XJ Cherokee
nice do you mind if i ask how much?
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 08:54 PM   #771
Weeder1
Which part? lol
Either one lol
-98 xj sport-
Unread 02-19-2013, 09:11 PM   #772
ibjeepin95
$175 for everything you see. The 5100's are corroded, but they have less than 5k miles on them.
Either one lol
Unread 02-19-2013, 09:20 PM   #773
Luke95
Travel on the 5100s?
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 02-19-2013, 09:28 PM   #774
ibjeepin95
10". Going to order 12" more than likely for the rear.
Unread 02-19-2013, 09:29 PM   #775
Luke95
7100?
Unread 02-19-2013, 09:43 PM   #776
ibjeepin95
7100?
Ha! I'm ballin' on a budget! 5100's dood.
Unread 02-19-2013, 09:44 PM   #777
Luke95
Nice...:P
Sent from my black box in my silver pos box
Unread 02-20-2013, 11:19 AM   #778
jeepnatv4life
road salts a beyotch
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 02-20-2013, 11:20 AM   #779
ibjeepin95
Yes it is. I hope to clean them up somehow.
Unread 02-20-2013, 11:23 AM   #780
Weeder1
Paint them white.....
-98 xj sport-
