ibjeepin95's 99' XJ Build - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-01-2012, 12:45 PM   #46
TOW_HOOK
1957 CJ3B
Haha, Clayton is what I'll go with. And I think I know what I'm doing for bumpstops. But right now I am looking for good prices on gears and master installs...
are you going with the radius arms then ? the johnny joints are bigger on the 3 link, plus you can upgrade to the 4th link for around 320$ if you want to add it later. it would take some exhaust mods but would work..
57 3b classic krawler /93 xj r.i.p. / 95 yj daily driver / 02 wj wife's ride / 98 xj wanta be rock krawler
TOW_HOOK is offline   Reply With Quote Quick reply to this message
Unread 03-01-2012, 07:55 PM   #47
ibjeepin95
ibjeepin95's Avatar
I'm not really sure yet. I decided I'm going to get the rear axle done first and wheel it on short arms ( the stock ones) for a little while. I like both designs, it's hard to decide!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2012, 08:21 PM   #48
ibjeepin95
ibjeepin95's Avatar
So I decided to pick up an 8.25 instead of swapping in the 8.8. It will just make things a little easier, has enough strength for me, and is the same gearing as the 30. I also ordered new u bolts, u bolt plates, extended front bumpstops, and some hockey pucks
Unread 03-02-2012, 11:53 AM   #49
jeepnatv4life
Makin Bald Far Stones worse
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 06:53 PM   #50
ibjeepin95
ibjeepin95's Avatar
Unread 03-04-2012, 07:06 PM   #51
ibjeepin95
ibjeepin95's Avatar
My 8.25 29 spline I got from Josh.... Faith approves.
Unread 03-05-2012, 01:03 PM   #52
ibjeepin95
ibjeepin95's Avatar
Ordered one of these today...
http://www.pirate4x4.com/forum/showthread.php?t=1011786
Unread 03-13-2012, 03:09 PM   #53
ibjeepin95
ibjeepin95's Avatar
No pics at this time but I do have the 8.25 swapped in but I got some headaches to take care of first ORS bumper came in and it is painted up, just need to put it on. I'll get some pics up this week....
Unread 03-13-2012, 03:13 PM   #54
JJeeper09
Get your cell man, I'll be in Richmond next week, might try and wheel some over break
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2012, 06:48 PM   #55
ibjeepin95
ibjeepin95's Avatar
Wait, where are you now? I thought you lived and went to school in Richmond...
Unread 03-13-2012, 07:29 PM   #56
JJeeper09
Ashland is my school Richmond is my home town: I'll be there. Come and get it
Unread 03-14-2012, 07:37 AM   #57
Clayton
When you put in your 8.25 did you use the center hole in the perch or slide it back so the spring pin was in the front hole. I dont know about you but I barely had any room at the front of the wheel well. So I slid mine back and gained an 1 1/2" of wheel base and needed clearance.
Clayton is offline   Reply With Quote Quick reply to this message
Unread 03-14-2012, 08:32 AM   #58
ClassicVA
put that bumper on and call me so I can see it dood. and lets go play in the woods, pronto.
~1998 Cherokee Classic - 3.5" RE Superflex, 32's
~XJ Owners Club Member #134
ClassicVA is offline   Reply With Quote Quick reply to this message
Unread 03-14-2012, 03:07 PM   #59
ibjeepin95
ibjeepin95's Avatar
I used the original center hole. Went back just like my 35 did. I'll get some pics up tomorrow.
Unread 03-14-2012, 03:08 PM   #60
ibjeepin95
ibjeepin95's Avatar
OOOORRR you could ride over tomorrow morning and help me put it on.....and get my E brake cables worked out. And shock mounts
