ibjeepin95's 99' XJ Build - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 09-17-2012, 09:08 PM   #301
BomberJeep
2003 WJ
Great work and great looking XJ man. Keep it up
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 09:20 PM   #302
ibjeepin95
Thanks dude! Good to hear from another VA Jeep guy!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 04:39 AM   #303
DezertXj88
1990 XJ Cherokee
Ok..so say you didn't do the shocks through the floor..what issue is there? When on 3" and 35's?
I mean obviously rubbing up front, bump stop & trimming is needed, same for the rear. Cut & fold recommended so your not rubbing..but what else is there?
DezertXj88 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 09:59 AM   #304
jeepnatv4life
have u read the hole thread lmao????? He has shock hoops in the rear......
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 11:23 AM   #305
crockett07
1992 XJ Cherokee
Whole*
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 12:32 PM   #306
Weeder1
Originally Posted by crockett07
Whole*
Lol just like a chick......
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 12:51 PM   #307
DezertXj88
1990 XJ Cherokee
Did you not read my question?
IF you didn't do shock through the floor, what would the potential issues/draw backs be
I know he has shocks through the floor, I'm asking the draw backs of 35's without them through the floor
Unread 09-19-2012, 01:54 PM   #308
alexrule123
It depends on the amount of lift you have. You have to trade up travel with down travel and have the shock body fit in the small amount of space under the jeep.
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 03:38 PM   #309
DezertXj88
1990 XJ Cherokee
Ya I figured it was more of a shock travel thing..basically with then mounted through the floor he can run a 14" or 16" or whatever to get the down travel he needed..
Unread 09-19-2012, 04:42 PM   #310
ibjeepin95
Yup, Alex has it right. I wanted to mount my lower shock mounts on top of the axle so they were out of the way. My lower mount is currently on the spring plate. The only shock I could could have mounted there would have been a stock style shock with no travel, so that wasn't happening. After I did the hoops, I continued (and still am) running the 10 inch shocks I had. Eventually, after I get to doing some shackle relocation brackets and redoing the springs, I will go to a 12 inch shock because it will give me the most down travel and just enough up travel.
Unread 09-19-2012, 05:57 PM   #311
DezertXj88
1990 XJ Cherokee
Aww so it was because you moved the lower mount. Thats what I was after. Shock shocks in stock location it shouldn't have an issue!
Unread 09-19-2012, 07:35 PM   #312
ibjeepin95
Yup. Main reason for the hoops was for longer shocks and just to simply outboard them. Outboarding them allows the shock to actually work like it's supposed to. Of course, fitting a shock was another important reason.
Unread 09-20-2012, 05:31 PM   #313
Weeder1
Well in think you need clayton lowers...
-98 xj sport-
Unread 09-20-2012, 06:26 PM   #314
ibjeepin95
I do. 150 is shipped?
Unread 09-20-2012, 06:41 PM   #315
Weeder1
Yupp
-98 xj sport-
