ibjeepin95's 99' XJ Build - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-04-2012, 02:02 PM   #286
ibjeepin95
Originally Posted by Brookhart63
Stock D 30's don't like 35s. Especially at full lock.
They hate full lock and skinny pedal. But they hold together on 35s better than most think they do.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2012, 02:16 PM   #287
Brookhart63
Had to change a shaft on some rocks this weekend. Like you said don't think your jeep is invincible
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2012, 08:07 PM   #288
ibjeepin95
Exactly. But sometimes I do
Unread 09-04-2012, 08:30 PM   #289
jeepnatv4life
The hell they wont. A full weld is absolutely stronger than stitch welds. I don't know why someone would stitch weld sliders in the first place, you stitch weld thin sheet metal so that you don't burn through or warp it.
if ur weldin2x6 to sheet metal/unibody going from a bunch of little stitch welds to a full on seam WILL NOT change anything because...............ur still welding to sheet metal. SO before you pipe in.....think before you speak
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 09-04-2012, 08:57 PM   #290
1990JEEPXJ
1990 XJ Cherokee
X2. Most will advise against fully welding things like frame stiffeners to the unibody. Fully welding are simply not necessary in a lot of scenarios
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 09-05-2012, 03:53 PM   #291
Weeder1
How you plannin on bracing the sliders?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 09-05-2012, 07:37 PM   #292
ibjeepin95
With metal . I am going to run three legs per side from the "frame" rail to the slider.... Kinda like this in post #17..... http://www.naxja.org/forum/showthrea...1075717&page=2
Unread 09-07-2012, 12:30 PM   #293
Weeder1
I gotcha. Im thinking of running supports out to the bottom of the 2x6 and plating under that to make like a boat side.
-98 xj sport-
Unread 09-07-2012, 02:17 PM   #294
DezertXj88
1990 XJ Cherokee
I was thinking of doing this as well..but at this point why not cut a few more inches up? Like what Eric did on his? Just curious honestly..it seems about the same amount of work either way?
DezertXj88 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2012, 04:08 PM   #295
ibjeepin95
It's a lot more cutting doing it that way. I will add 2 or 3 legs to mine. Got the metal to do it today.
Unread 09-13-2012, 07:02 PM   #296
ibjeepin95
Re-painted my Hyline Hood vents..... still waiting on templates.
Unread 09-16-2012, 07:35 AM   #297
ibjeepin95
Got my frame stiffeners on yesterday. I can tell a big difference with them on. I'll get better pics later.
Unread 09-16-2012, 07:36 AM   #298
ibjeepin95
Here is another pic I got, showing how bad I need to rebuild the leaf packs and do a shackle relocation....
Unread 09-17-2012, 07:00 PM   #299
jeepnatv4life
take some close up pix main
'13 RZR 570
Unread 09-17-2012, 07:55 PM   #300
ibjeepin95
I will. They are just like everyone elses haha
