ibjeepin95's 99' XJ Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > ibjeepin95's 99' XJ Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 02-11-2012, 07:24 PM   #16
ibjeepin95
Thanks James. I got more, I'll get them up Monday night. I work three 12's Saturday, Sunday, Monday, so I'm kinda tired. Btw, that's a cell phone pic. Anyways, I got a lot of things to work out. For now, it's able to be driven, and I have been driving it. The shop balanced the tires but I don't think they are right because it has a little bit of shimmy til about 55-60. As far as flex, bump stops will happen within the next week or two. I also need to clean the front fender trim up some, as it was a quick job just to get the tires on. Like I said, I got a lot of things to do before it's "right" in my mind. D35 probably won't like wheelin' those big tarz. Though I've done it before...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 02-12-2012, 10:13 PM   #17
glen6251
4.5 clears the 35's pretty nice. maybe some coil spacers and shackles with your lift will also help it out a little bit.
on my girls cherokee i did the 4.5 with a shackle in the back and bushwacker flat flares and it clears 35's fine for flex and we didn't trim much.
ill be following curious to how it will all end up
My build Thread - [URL="http://www.jeepforum.com/forum/f22/cherokee-fever-1429680/#post14333391"]http://www.jeepforum.com/forum/f22/cherokee-fever-1429680/#post14333391[/URL]
glen6251 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2012, 12:58 PM   #18
jeepnatv4life
more lift would take away from being low..........
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 02-15-2012, 01:07 PM   #19
kyle_craig
The new rig looks awesome man! Cherokees are pretty neat!
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 02-16-2012, 05:22 PM   #20
ibjeepin95
True dat Josh. Why add more lift? Flex can be made. And it's ok Kyle, no one will hate cause you truely love XJ's
Unread 02-16-2012, 05:28 PM   #21
ibjeepin95
BTW, new pics...
I also pulled the wheel weights off cause they weren't balanced right. They actually ride better with no weights. Has some shimmy in the front, so I ordered a a steering stsbilizer.....from Rusty's I figured they couldn't screw that up, plus I ordered the one with heims. This one: http://rustysoffroad.com/mm5/merchan...egory_Code=ste
We will see how it goes. I need to order a new tie rod cause the stock one is hatin' life right now. Also, I will probably be doing my SYE next Wednesday. Anyone have any idea if a stock front shaft will work with around 3 inches of lift??
Unread 02-16-2012, 05:30 PM   #22
ibjeepin95
Another thing, after I get my taxes back, I'll order the simple swap kit from Ruff Stuff and start doing my 8.8 swap
Unread 02-16-2012, 10:39 PM   #23
glen6251
thats always tru that flex can be mad and i bet it will be a very capable rip. but everyone has their own style. mine is just clean and not hacked
Unread 02-16-2012, 10:41 PM   #24
glen6251
is it you dd? how do you like those tires for the on road usage? and what else is in store for the front end because of the 35's? i see tie rodand stabilizer, but anything else?
and yea the front drive shaft will be fine. hers is at 4.5 and still good. no problems so far.
Unread 02-17-2012, 07:11 AM   #25
ibjeepin95
I don't think mine looks hacked but to each their own opinion. It's not my DD but the tires ride smooth on the road. Lots of things to come. Most likely getting a 3 link with Currie JJ's on every end, 1 ton steering down the road and a steering box brace. Probably some unibody plating later on also.
Unread 02-22-2012, 11:54 AM   #26
ibjeepin95
Yesterday I got the stabilizer from Rusty's and slapped it on. Sad part is I really can't tell a difference
Today I picked up a drive shaft from an auto XJ so I can do my SYE. I don't think I mentioned it before but I do have a new SYE that I kept from my TJ.
On a side note I found out what I am getting back from my taxes and a Clayton Pro series 3 link may be on order sooner than I thought
Unread 02-22-2012, 02:59 PM   #27
bigdhamYJ
Gorgeous XJ man! you shouldn't have a problem with the front drive shaft at that height. My old ZJ ran 4.5" and my YJ at 4.5" and now 3" haven't had a problem with the factory drive shafts. I laughed so hard when you said "cause you ain't wheeling in the south unless your on white shocks...." Sad but true
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline   Reply With Quote Quick reply to this message
Unread 02-22-2012, 04:45 PM   #28
V1GiLaNtE
^^ Oh wow hey now.. I just noticed you're profile says Harrisonburg, VA!!??
How is it I haven't seen you rollin around man?? I'm a super senior here at JMU.. maybe seen me rollin around?
98' Classic with a rear swing out and the Hellas..
Just got my IRO trackbar tuesday which is the last of the parts I needed to go 3.5"..now I have to find the damn time to put everything on..
We should do some wheelin sir!
Build is coming along nicely!!
V1GiLaNtE is offline   Reply With Quote Quick reply to this message
Unread 02-22-2012, 05:21 PM   #29
ibjeepin95
Yessir, you commented on my TJ build when I had that lol. We sometimes wheel GWNF but here lately (or last time we really wheeled) we go over to Crozet. It's some great wheeling over there. Hit the RCPFA link in my sig.
Unread 02-22-2012, 05:22 PM   #30
ibjeepin95
Thanks man. And yup, it is true. Cheap shocks for the win. YEEEEEEEEEEE HAAAAWW!!!
